Identifying Comp Cam
Old Sep 3, 2009 | 04:08 PM
BerBer5985's Avatar
Is there anyway to identify the cam the previous owner has put into the engine without taking the engine apart? I have no info other than it's a comp cam, but no idea on specs. I believe the original 68 350 was replaced with a 73 350 and then has had a cam put in it.
Old Sep 3, 2009 | 04:37 PM
captjim's Avatar
You can degree the cam and get lift and duration #s, then look in the Comp catalog. But, with hydraulic lifters it will not be 100 % accurate. Still, the lift #s should get you pretty close.
olds 307 and 403
Jun 9, 2013 04:08 PM
Kidcutty
Feb 3, 2010 05:56 PM
MN71W30
Jun 23, 2009 07:24 PM
olds382
Nov 11, 2008 11:47 AM
