Anyone ever use a XE268H Comp cam?
Old Jun 22, 2009 | 05:37 AM
MN71W30's Avatar
I'm close to buying a XE268H comp cam for a 9.5-1 455 Olds with a 4 speed 3.42 gears, with manifolds. I had a comp cam lose a lobe on a 454 BBC a couple years back after about 900 miles, I did have some super stiff springs and wasn't aware of the zinc issues. Is there a someone out there that has ever used one? I am looking for low end power and a fair idle.
I would sure like an pinion.
Old Jun 22, 2009 | 01:13 PM
chris83's Avatar
i havent used a 268 but i am running a extreme energy 284 h wich is a awsome cam you can hear it on my video on the big block forum and major builds forum on here its titled my new video of my custom 462 big block
Old Jun 22, 2009 | 04:01 PM
380 Racer's Avatar
IMHO you want a split lift/duration cam unlike a Chevy.
Old Jun 23, 2009 | 06:35 PM
cutlassefi's Avatar
Comp 268
I agree with 380 racer, especially since you're using manifolds. You could use the extra lift and duration on the exhaust side.
You don't have to pick something off the shelf you know. Most cam companies will do a custom grind for a just a few bucks more. I did a Lunati Hyd. Flat tappet for a SBO, ran awesome. Specs were 223/231 @ .050 on a 108, .525/.550 lift. Just a suggestion.
Old Jun 23, 2009 | 07:24 PM
MN71W30's Avatar
I guess I need to consider a custom grind. The Olds 268 is a split duration 224 230@.050. The numbers seem to be where I want them. I had Ultradyne do that in the past and they seemed to work great. I would like to keep the lift low enough for stock springs and I'm more interested in having low end torque than high RPM HP. I have a Voodoo cam in my BBC and it worked out very nicely. I think I'll call Lunati tomorrow.
Thanks guys.
Dave
Jerry the wrench
Nov 3, 2014 10:23 PM
scrappie
Sep 27, 2012 06:57 AM
Raivjudge
Jan 30, 2012 09:44 AM
oldzy
Jul 29, 2011 12:24 AM
jensenracing77
May 5, 2011 10:08 AM
