69 cutlass 350 tune-up
Old Jun 23, 2009 | 04:11 AM
cutlass cool's Avatar
does anyone have the spec's on tuning up a 69 cutlass with a 350 rocket, auto trans and 4 barrel (dwell, timing and piont gap)
Old Jun 23, 2009 | 04:14 AM
Oldsguy's Avatar
Past Administrator
Don't know exactly off the top of my head but 10 degrees advanced with vacuum dis-connected would get it running, dwell should be about 28 to 32. I was just doing some morning maintenance on the site and just saw you post come up and wanted to say Welcome to CO.
Old Jun 23, 2009 | 01:06 PM
svnt442's Avatar
There is no listing for the point gap in the service manual, just the dwell. 30° +/- 2°.
Initial timing is set to 8°-10° depending on the engine. (310 or 325 HP) Initial should be set @1100RPM with the vacuum disconnected and plugged, not idle.
Old Jun 23, 2009 | 01:37 PM
B-Mann's Avatar
I am about to do the same to my old 350 72 Cutlass S, would these be the same settings I will be going for?
Old Jun 23, 2009 | 05:56 PM
svnt442's Avatar
For the 72 I believe the only difference will be the base timing only has one setting. Stock should be 8º @1100 RPM. You can get away with more though.
Old Jun 24, 2009 | 11:06 AM
69 Cutlass tune-up
thanks to all for the info
Old Jun 29, 2009 | 08:45 PM
B-Mann's Avatar
Can you tell me what the point gap should be set at with a feeler gauge when replacingthe points for my 72 350, we just need to get it started to set the dwell. thanks for all your help you guys are a lot of help.
Old Jun 29, 2009 | 11:39 PM
88 coupe's Avatar
Junior Member
Originally Posted by B-Mann
........ point gap should be set at with a feeler gauge ........
.016" gap = 30° of dwell.
Norm
Old Jul 2, 2009 | 02:26 PM
B-Mann's Avatar
Thank you very much you have been a lot of help.
h/o guy
Feb 24, 2015 06:51 AM
nj_cutlass72
Aug 18, 2011 04:59 AM
gypsy66delta
Aug 19, 2008 12:54 PM
southcarolina803
Jul 8, 2008 07:37 PM
RussTad
Sep 14, 2006 04:09 PM
