69 quadrajet question
Old Jul 2, 2009 | 09:17 PM
PmL69's Avatar
ok...so i needed my carb rebuilt & heli-coiled. I was talking to a guy i work with & he says he knows these people who rebuild carbs for a living & he would "hook me up" He says it will only take a week & all it will cost is parts. i say awesome!!
So a week later i see my co-worker & he says he has some bad new about my Quadrajet. He proceeds to say that his guys wouldnt rebuild it. The rebuild wouldnt be a problem, the heli-coil of the fuel inlet wouldnt be a problem. I was told my quad was junk & i should get a Edelbrok for my cutlass & through the quad over a bridge. I was told the my quadrajet suffers from a "very commen problem" which is the bottom base plate that mounts to the intake was junk. From what i was told the throttle linkage shaft has play in it. I checked it, it moves a little.... i guess....
My question is
is this a commen problem or did these guys just not to want to mess with my carb.
Ive never really heard of this problem. the carb ran fine. the only reason i quit running it was cause of the fuel inlet leak. i did the jb weld trick on it & it stoped the leak but after a year of sitting in a box the floats were sticking bad so it needs rebuilt. i thought if it needs rebuilt im gonna fix the leak the right way.
any input would be great
Old Jul 3, 2009 | 05:09 AM
88 coupe's Avatar
Junior Member
Originally Posted by PmL69
........ or did these guys just not to want to mess with my carb ........
Either that, or they are not competent.
I was told my quad was junk & i should get a Edelbrock ........
This is a good indication that they are not competent.
Contact Danny (70Wcars) on this site, via PM, or go to http://www.sparkyscarbs.com for more.
Norm
Old Jul 3, 2009 | 05:19 AM
380 Racer's Avatar
I have heard nothing but good comments about Sparky's.
Old Jul 3, 2009 | 06:52 AM
Worn throttle shaft bushings in Q-jets (and ALL other types of carbs) is common. There are bushing and reamer kits to repair this. Find a competent carb rebuilder if you do not want to do it yourself.
auto_editor
Dec 20, 2010 11:24 PM
Mister
Apr 5, 2010 12:06 PM
1964CutlassSC
Feb 18, 2010 08:05 PM
sworthy555
Feb 16, 2010 08:25 PM
sixty9olds
Sep 10, 2009 04:56 AM
