69 quadrajet question
Old July 2nd, 2009, 09:17 PM
PmL69's Avatar
ok...so i needed my carb rebuilt & heli-coiled. I was talking to a guy i work with & he says he knows these people who rebuild carbs for a living & he would "hook me up" He says it will only take a week & all it will cost is parts. i say awesome!!
So a week later i see my co-worker & he says he has some bad new about my Quadrajet. He proceeds to say that his guys wouldnt rebuild it. The rebuild wouldnt be a problem, the heli-coil of the fuel inlet wouldnt be a problem. I was told my quad was junk & i should get a Edelbrok for my cutlass & through the quad over a bridge. I was told the my quadrajet suffers from a "very commen problem" which is the bottom base plate that mounts to the intake was junk. From what i was told the throttle linkage shaft has play in it. I checked it, it moves a little.... i guess....
My question is
is this a commen problem or did these guys just not to want to mess with my carb.
Ive never really heard of this problem. the carb ran fine. the only reason i quit running it was cause of the fuel inlet leak. i did the jb weld trick on it & it stoped the leak but after a year of sitting in a box the floats were sticking bad so it needs rebuilt. i thought if it needs rebuilt im gonna fix the leak the right way.
any input would be great
PmL69 is offline
Old July 3rd, 2009, 05:09 AM
Junior Member
88 coupe's Avatar
Originally Posted by PmL69
........ or did these guys just not to want to mess with my carb ........
Either that, or they are not competent.
I was told my quad was junk & i should get a Edelbrock ........
This is a good indication that they are not competent.
Contact Danny (70Wcars) on this site, via PM, or go to http://www.sparkyscarbs.com for more.
Norm
88 coupe is offline
Old July 3rd, 2009, 05:19 AM
380 Racer's Avatar
I have heard nothing but good comments about Sparky's.
380 Racer is offline
Old July 3rd, 2009, 06:52 AM
Worn throttle shaft bushings in Q-jets (and ALL other types of carbs) is common. There are bushing and reamer kits to repair this. Find a competent carb rebuilder if you do not want to do it yourself.
joe_padavano is offline
auto_editor
December 20th, 2010 11:24 PM
Mister
April 5th, 2010 12:06 PM
1964CutlassSC
February 18th, 2010 08:05 PM
sworthy555
February 16th, 2010 08:25 PM
sixty9olds
September 10th, 2009 04:56 AM
Quick Reply: 69 quadrajet question
