plug gap and timing
Old Jul 3, 2009 | 06:16 PM
'70CutlassHoliday's Avatar
plug gap and timing
Ok I just finished rebuilding my 1970 350.
Could someone tell me what the plug gap and timing should be?
I think its .035 and 12 degrees
I have an MSD 6a ignition and pro billet distributor will this change the gap I need?
I'd rather ask stupid questions and get things right than to do it wrong.
Thanks!
Old Jul 3, 2009 | 07:30 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
.035 sounds like a good gap.
As far as timing goes, it depends on your compression ratio.
If it's pretty much stock, 12 is a good base, and in between 25 and 35 degrees total@3800 should be fine.
Old Jul 4, 2009 | 12:25 AM
88 coupe's Avatar
Junior Member
Originally Posted by '70CutlassHoliday
........ I have an MSD 6a ignition and pro billet distributor will this change the gap I need? ........
Not unless you have less compression, leaner mixtures, and higher coolant temperatures.
Norm
Old Jul 4, 2009 | 06:28 AM
ok thank you
Norm
ok, I was hoping you would answer
thanks
I'll be sure to post pictures and a video once I get the chance.
bonesbmx
Jun 2, 2020 02:10 PM
dallasite21
May 25, 2012 09:07 PM
ChrisM
Mar 7, 2009 08:07 PM
ChrisM
Nov 1, 2007 02:23 PM
66starfire
Jan 3, 2007 10:31 AM
