Timing and Spark Plug Gap for 350
Old Oct 31, 2007 | 10:23 AM
ChrisM's Avatar
Hello all,
I recently converted the 350 engine in my '73 Delta 88 to a Pertronix electronic ignition. I need to set the timing and my repair manual says to see a sticker in the engine compartment, but the owner before me had removed all stickers in a repaint effort. Does anyone know what the proper timing setting is for my car? Also, I want to put a new set of spark plugs in, but I don't know what the gap should be set at?
Thank you all in advance,
Chris
Old Oct 31, 2007 | 03:06 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
I believe it is 17 or 18 degrees below top dead center @1100
gap for a 307 is.060
I would think they are the same.
I'd go with that on ACDelcos
If you're using Champions id go .040
Old Oct 31, 2007 | 06:00 PM
88 coupe's Avatar
Junior Member
Use of Pertronix trigger, in place of points, doesn't change the settings.
Plugs = AC R45S gapped at .035"
Timing = 12° BTDC.
Norm
Old Oct 31, 2007 | 06:15 PM
Wow, slight difference between a 1980 350 and a 1973 350.
Thanks Norm.
Old Oct 31, 2007 | 06:19 PM
Oldsguy's Avatar
Past Administrator
Oh for sure! In '69 the gap was .030 and the advance was only about 8 btdc. Just shows that the engines will run well with varying settings depending upon the distributor and the junk loaded on top of the manifold for smog regs.
Old Nov 1, 2007 | 08:41 AM
ChrisM's Avatar
Thank you all for your help! I will try out the plugs gapped at .035 and the timing at 12 degrees BTDC tonight. This is all very new to me, and I am bumping my way around this car. Thanks again.
Chris
Old Nov 1, 2007 | 03:37 PM
Originally Posted by Oldsguy
Oh Just shows that the engines will run well with varying settings depending upon the distributor and the junk loaded on top of the manifold for smog regs.
So do you have to compensate if you rip all of that crap out?
Old Nov 1, 2007 | 04:43 PM
88 coupe's Avatar
Junior Member
No reason to.
That "junk/crap/etc" has nothing to do with the spark advance/plug gap, or the power output of that engine.
Might be an oversimplification, but, advance requirements are determined by cylinder pressures (compression ratios) and the plug gaps, by fuel mixtures.
Norm
Old Nov 1, 2007 | 09:01 PM
Thanks again Norm.
I appreciate your straight answering style on here.
Old Nov 2, 2007 | 10:18 PM
Redog's Avatar
point ign .032
HEI ign .045
When I when from points to HEI, I regapped all the plugs from .030 to .045
Old Nov 3, 2007 | 08:23 AM
88 coupe's Avatar
Junior Member
Originally Posted by Redog
point ign .032 ........ HEI ign .045 .......
Nothing to do with the distributor.
Increase in gap was because of the change to lean mixtures that were used to meet emissions standards.
On a pre '74 factory engine, .032" or .045" will work fine. '74 and later will need .045" to run satisfactorily.
Norm
Old Mar 6, 2009 | 11:30 AM
ChrisM's Avatar
Timing = 12° BTDC.
Norm
What RPM do I set the timing at? 1100?
Old Mar 6, 2009 | 11:33 AM
Redog's Avatar
^^ Yes
Old Mar 6, 2009 | 06:10 PM
ChrisM's Avatar
^^ Yes
Do I need to plug any vacuum lines? I recently had a MSD coil and distributor put in and I thought I heard somewhere that you have to plug some vacuum lines when setting the timing. If I do, which lines do I plug?
Old Mar 7, 2009 | 08:07 PM
88 coupe's Avatar
Junior Member
Originally Posted by ChrisM
........ which lines do I plug?
Remove and plug the hose from the vacuum advance canister.
Set the advance.
Unplug and return the hose to the can.
Norm
bonesbmx
Jun 2, 2020 02:10 PM
dallasite21
May 25, 2012 09:07 PM
yeahbuddy
Apr 27, 2012 10:45 AM
ChrisM
Nov 1, 2007 02:23 PM
66starfire
Jan 3, 2007 10:31 AM
