Newb ? RE: Head ID
Old May 27, 2009 | 09:47 AM
A72CUTLAS's Avatar
Tha' Big Dog
Question Newb ? RE: Head ID
Hey guys...
As stated this is probably a newbie(read stupid) question but before reading another post I had know idea that there were different heads for the 350R. How can I tell which # head I have? And which one is better for performance?
I've learned that #8's are crappy smog heads, and I've read that alot of people have #7's. Are they the best or just most common? All replies are appreciated.
Hey..... I'm out of newbie jail!!!
Old May 27, 2009 | 10:46 AM
70Wcars's Avatar
The #5 from 1969 and # 6 from '70 both have smaller combustion chambers I believe. I have worked on both and found that the #5 require almost no work on the short turn above the valves and none in the bowl area when porting. Perhaps a better casting from the factory.
Hope this sheds some light on your question.
Danny
Old May 28, 2009 | 12:12 AM
A72CUTLAS's Avatar
Tha' Big Dog
Thanks for the info, I hope I have the #5's. Where would I look to find out?
Old May 28, 2009 | 05:07 AM
2blu442's Avatar
If your alternator is on the drivers side look right under it. Attached is a photo of a set of heads, note the large number 5 on the left corner just to the left of the spark plug hole and under the head bolt hole. John
Old May 28, 2009 | 07:19 AM
Warhead's Avatar
#8 heads have a larger (80cc) chamber, but that is it. Otherwise identical to #7 (68cc) heads.
#5 heads (68-69) do have a lower port floor, also has a lower bowl. cross section is the same as #7's, flow about the same. You can not lower the #7 head floor as low as the #5 (68cc) without risking water.
I like the #5's, myself.
What year 350 (R???) block do you have?
Early heads use 7/16 head bolts, later 350's use 1/2 inch head bolts and require early head bosses to be drilled to 17/32nd's for the early heads to bolt onto late blocks.
Jim
Old May 29, 2009 | 01:03 PM
A72CUTLAS's Avatar
Tha' Big Dog
Mines a '72
Thanks guys for the info. It's a '72 350 that I have. I plan on getting some pics I can post tonight. The car is pretty straight, just sorta neglected due to no garage for the first 7+yrs I owned it. My plan is to do the exhaust and disc conversion, then make her look pretty again. Then later I'll do the engine, maybe a 455 so I can really be a 442 wannabe.
Old May 29, 2009 | 04:13 PM
A72CUTLAS's Avatar
Tha' Big Dog
I've found that my heads are #7's. Not ready to do any engine work now, but this info will come in handy later.
young olds
Jun 3, 2014 08:13 PM
Olds Scott
May 29, 2013 08:15 PM
Ragtopw1972
Oct 18, 2012 08:19 AM
CLcutlass
Aug 21, 2011 06:25 PM
arnyishere
Nov 9, 2007 12:13 PM
