Lifter question
Old Jul 2, 2009 | 02:19 PM
B-Mann's Avatar
Lifter question
i recently rebuilt my motor and before installing the lifters I couldn't pump all of them manually to get oil in them. My question is will they pump themselves up when the motor runs or do i have to take them back out and try to push them in? Thanks guys just don't want to mess up new lifters.
Old Jul 2, 2009 | 02:33 PM
Oldsmaniac's Avatar
I usually soak em in oil before installing but when you pre-lube the engine before starting oil will be circulated to the lifters.
Old Jul 3, 2009 | 02:53 PM
B-Mann's Avatar
We did soak them but wasn't able to pump them before installing.
Old Jul 3, 2009 | 11:56 PM
B-Mann's Avatar
I'm affraid of running my motor and messing it up without knowing for sure if it is bad to not of pressed the lifters to fill them with oil before putting them in, we tried but they were very hard to push in. If someone could let me know everything will be cool if i just let them work in themselves it would make me feel a lot better.
Old Jul 4, 2009 | 12:55 AM
88 coupe's Avatar
Junior Member
Originally Posted by B-Mann
If someone could let me know everything will be cool ........
I will. Post #2 told you what you need to know.
Oldsmaniac likes to pump them up. I don't, because I like to check preload when they are empty.
Makes no difference as, either way, they will be filled when you do the prelube.
Norm
Old Jul 4, 2009 | 01:08 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
While we're on the subject....
What is your preload going to be set at?
I've always set mine to .020 and it has worked out well.
I called Milan's High Performance Olds, and he recommended .030 -.060
I also called up D.R.D. Racing in Wisconsin and .040 was recommended.
My chassis service manual states .005 -.020
It'd be interesting to get some field measurements of what preload everyone is running and why.
Old Jul 4, 2009 | 05:58 AM
380 Racer's Avatar
When prelubing the engine with hyd lifters (or any lifter) Run the pump for a few seconds, turn the crank 90 degrees, prime.....turn the crank 90 until you have oil in all.
Jay, Milan told you that because that puts the lifter in the center of the travel. Was that manual a Mondello? He states that is for a racing motor. I used to run.005-.010 to get them to act like a solid. Ask Milan, he will tell you the same.
Old Jul 4, 2009 | 07:46 AM
My Manual is a 1980 Oldsmobile Chassis service manual.
Center of travel sounds like a good happy medium to me.
Old Jul 4, 2009 | 10:04 AM
380 Racer's Avatar
OK thanks, I had never seen that before. Yes I am still learning .
Old Jul 4, 2009 | 10:34 AM
We all are.
Old Jul 4, 2009 | 04:53 PM
88 coupe's Avatar
Junior Member
........ It'd be interesting to get some field measurements of what preload everyone is running and why.
Adjustables, in most cases = ⅛ of a turn down.
Fixed, in most cases = Doesn't matter as long as there is no "tick" or they are not bottoming out.
Exceptions? Whatever it takes to correct valvetrain geometry.
Norm
Old Jul 6, 2009 | 10:11 AM
88 coupe's Avatar
Junior Member
Originally Posted by 380 Racer
........ I used to run.005-.010 to get them to act like a solid .......
Any preload (.005") causes it to act like a hydraulic. To make a hydraulic act like a solid, it must be completely collapsed, so any "damping" effect is eliminated.
Norm
1970supremevert
Jan 19, 2013 02:23 PM
Railguy
Apr 9, 2012 07:29 AM
pontiac1
Feb 11, 2012 06:30 PM
Troys Toy 70
Feb 3, 2012 07:59 AM
#1CutlassSupreme
May 13, 2008 10:40 AM
