cam thrust issue
Old Aug 9, 2009 | 01:20 PM
84 rocket's Avatar
cam thrust issue
So i tore down my 69 olds 350 and before stripping the block and hot tanking it i saw the timing oiler was pluged and had been for awile no oil to the timing gears and front of the cam! the cam thrust made the cam eat the block about .030 I know about the big block chev's doing this and shimming to corect the issue. can some one chime in and give suggestions?
Old Aug 13, 2009 | 08:43 PM
84 rocket's Avatar
ttt
Old Aug 14, 2009 | 05:57 AM
kaz442's Avatar
On the motor in my F85 I had the block machined to accept a torrington bearing that goes between the cam and the block. Don't remember how much was removed but I do know some material was also removed from the cam sproket on the timing chain also. Something to look into. JKaz
Old Aug 14, 2009 | 08:11 AM
Oldsguy's Avatar
Past Administrator
Moved to "small block" forum to get more exposure, hopefully...
Old Aug 14, 2009 | 09:00 AM
Run to Rund's Avatar
I had a brass spacer made for that purpose once. I cut the cam .030 and the spacer is .060" (stronger). I think some of the vendors sell them, or go to a machine shop with the cam for the id-od dimensions they need.
Old Aug 14, 2009 | 10:33 AM
380 Racer's Avatar
Same as Jeff, I have a torrington bearing machined into the block.
Wheels and Tires
May 22, 2011 07:00 AM
Robert Kiedrowski
Jan 25, 2011 04:31 PM
Insom
Dec 6, 2010 05:53 AM
KustomRocket88
Nov 17, 2010 04:52 PM
