CTK-499 Camshaft Thrust Kit????
Old Dec 2, 2010 | 06:49 AM
Insom's Avatar
How important is this part?
Old Dec 2, 2010 | 10:12 AM
Run to Rund's Avatar
unlike Chevy, Olds engines pull the cam into the block. I shim the bolt so the head is close to the cover (flush with block, separated by gasket thickness) occasionally, just so the cam can't walk and disturb the ignition timing. I will eventually look around for a brass cup plug that fits over the nose of the bolt and trim the bolt nose for that amount of clearance.
Old Dec 2, 2010 | 12:22 PM
WMACHINES's Avatar
OPP sells a roller bearing that goes on the cam bolt. This way there is no metal wear with brass or alum. Nice piece from Andy Miller. http://www.oldsperformanceproducts.c...tures/2103.jpg
regards
Last edited by WMACHINES; Dec 2, 2010 at 12:25 PM. Reason: forgot the link for the bearing
Old Dec 2, 2010 | 02:26 PM
380 Racer's Avatar
I had BTR machine a torrington bearing in behind the cam into the block to take care of the thrust like Rund said. My ex-engine builder installed a bolt in the timing cover and put pressure on the cam bolt, putting the pressure in the wrong direction. You also cannot just install a torrington bearing between the cam and block.
Old Dec 4, 2010 | 04:45 PM
Insom's Avatar
Did the engine come with a special bolt installed from the factory? Is it needed?
Old Dec 6, 2010 | 01:08 AM
Insom's Avatar
Anyone know if this part came equipped from the factory? Is it needed or is it a money maker like the oil restriction plugs ?
Old Dec 6, 2010 | 05:53 AM
WMACHINES's Avatar
I use the roller bearing to keep the camshaft from walking back and forth. I have used the bronze bushings in the past. The timing of your distributor will be more constant. It is a great idea. I also dont use restrictors, but I do use the cam bearing.
regards
atkinsom
Nov 3, 2013 06:59 PM
nj_cutlass72
Mar 4, 2012 05:49 PM
Robert Kiedrowski
Jan 25, 2011 04:31 PM
84 rocket
Aug 14, 2009 10:33 AM
