HEI wiring up for older olds
here we go again, in a 1965 olds cutlass w/ 1975 olds 350 am thinking that from the batt connection on the hei to the pos relay on the fender well w/ a cut off switch in the wire betwwen the two this would be a two fold set up. one. thief deterant, two. gives the hei the 12 volts to operate, am I ok with this thinking?..... jim trying to keep it simple as am still running the externial regulated alt.....jim
That would work but you may get tired of reaching into the engine compartment every time you need to start the car, especially in winter time, plus you draw more attention to yourself and someone is bound to notice that activity. If the person you are protecting the car from as a potential car thief notices that activity they will know right where to look for the cut off switch. You might want to put the switch inside the car hidden someplace.
dan, yes you are so right but Iam wanting to put the switch under the dash to the left of the steering colum and this car will never see winter as it never has. so will this set up work?...jim
I was thinking under the drivers seat, by the track lever would be a good candidate for a keyed switch location, if it were tucked up out of site it would be the last place a thief would be looking...just a thought.
you know a key switch sounds like a do able thing, and makes the car harder to steal, but using a 12 volt source is ok for hei? as removing the ballist wire requires unwrapping the harness and mine is very good shape plus I have an external alt and hei requires a internal regulator, so not to cook the modual, so this set up would be ok?...jim
joepenoso
Jun 4, 2014 01:56 PM
ccnclassicoldsmobile
Jun 12, 2012 06:27 AM
