HEI wiring up for older olds
Old Jul 23, 2009 | 03:44 AM
65cutty's Avatar
Question HEI wiring up for older olds
here we go again, in a 1965 olds cutlass w/ 1975 olds 350 am thinking that from the batt connection on the hei to the pos relay on the fender well w/ a cut off switch in the wire betwwen the two this would be a two fold set up. one. thief deterant, two. gives the hei the 12 volts to operate, am I ok with this thinking?..... jim trying to keep it simple as am still running the externial regulated alt.....jim
Old Jul 23, 2009 | 04:12 AM
Oldsguy's Avatar
Past Administrator
That would work but you may get tired of reaching into the engine compartment every time you need to start the car, especially in winter time, plus you draw more attention to yourself and someone is bound to notice that activity. If the person you are protecting the car from as a potential car thief notices that activity they will know right where to look for the cut off switch. You might want to put the switch inside the car hidden someplace.
Old Jul 23, 2009 | 05:20 AM
65cutty's Avatar
dan, yes you are so right but Iam wanting to put the switch under the dash to the left of the steering colum and this car will never see winter as it never has. so will this set up work?...jim
Old Jul 23, 2009 | 09:35 AM
citcapp's Avatar
This would work. For the under dash switch I would use a key switch, the type where you can remove the key in the off or on position. First place the thief is under the dash.
Old Jul 23, 2009 | 10:07 AM
csstrux's Avatar
I was thinking under the drivers seat, by the track lever would be a good candidate for a keyed switch location, if it were tucked up out of site it would be the last place a thief would be looking...just a thought.
Old Jul 24, 2009 | 04:49 AM
65cutty's Avatar
you know a key switch sounds like a do able thing, and makes the car harder to steal, but using a 12 volt source is ok for hei? as removing the ballist wire requires unwrapping the harness and mine is very good shape plus I have an external alt and hei requires a internal regulator, so not to cook the modual, so this set up would be ok?...jim
Old Jul 24, 2009 | 06:27 AM
I've never heard this before. You should just have to run 12V ignition to the HEI distributor to make it work.
Old Jul 29, 2009 | 03:59 AM
65cutty's Avatar
want to thank all of you for great advice, you are the best...jim
Old Jul 29, 2009 | 05:21 AM
Oldsguy's Avatar
Past Administrator
I think you don't have to worry about the internal/external regulator problem, I haven't heard of that either. Where did you hear that?
Old Jul 29, 2009 | 09:05 AM
65cutty's Avatar
oldspower.com
Old Jul 29, 2009 | 07:57 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Not anymore. The whole internet knows now.
joepenoso
Jun 4, 2014 01:56 PM
oldsmobile1915
Feb 14, 2014 04:20 PM
ccnclassicoldsmobile
Jun 12, 2012 06:27 AM
oldscruiser
Feb 15, 2011 12:44 AM
65cutty
Apr 13, 2009 11:17 AM
