- Where can I find Head Bolts?
- Quick Question
- '66 Cutlass 330 Build Advice
- Exhaust clamps
- VACUUM ADVANCE
- my olds 350
- Moisture out the tailpipes?
- running a mechanical advance distributor
- sonic check
- Mystery block
- 56 Olds 88 324ci timing chain question
- 1956 324ci oil capacity and fuel pump ?
- Felpro Head Gaskets
- 371 bore
- 350 vacuum issues
- Rebuilding the 350!
- Engine ID help
- oil pressure? in the 85 olds
- Engine decoding?
- Small Block Identification help
- 350 motor mounts
- Dipstick removal
- 307 or 350 ?
- Should I keep the 307 or uprgrade to 350
- Distributor HEI conversion
- Small block and I mean really small
- need help
- headers
- vacume line routing
- Timing Marks
- Timing indicator question
- 750 cfm Holley carb question
- Headers
- Olds 350 Refresh
- Electric choke
- 350 rebuild
- bolt size?
- heater delete
- What size is my carb?
- Holley carb question
- Having trouble with intake...
- Need to find out what kind of motor this is in my cutlass
- The '69 dual snorkel breather...
- Pulleys for a 350
- OIL Pump
- 350 SB Heads
- Grrrr My new dilema
- TEAR DROP VALVE GUIDES
- I could use some carburetor ideas.
- Alternator Bracket
- performer rpm intake on # 7 heads
- olds 8.5 rearend question
- 2 core or 3 core?
- Aurora engine swap
- Ported Vacuum Switch
- POR 15 engine paint
- i have a stock 1972 350 with # 7 heads
- 71 Cutlass supreme Headers
- Head Gaskets Olds 260 4,3 V8
- Max Valve Spring on stock springs
- Suddenly Rich (a little O/T)
- Damer bolt..
- Cam 180 out?
- lower radiator hose on 330ci
- Enginenumber
- Timing for a 77 350
- Carb Question
- refreshed 350
- gear drive's good or bad
- HYD lifter pre load
- 75 OLDS 350 CR
- Know where to find a rubber bump stop kit?
- Air fuel problems
- A Few 350 Questions
- Rocket to SBC swap
- Exhaust question
- Lag Question
- Can't find piston for 350
- 350 Diesel to 440 kit on ebay, Cheap!
- Cold Air Intake
- Intake swap
- olds 350 rocket heads
- Dnyo run today
- rochester carb info help
- 350 Rocket?
- 64 olds cutlass f85 body mounts
- Fresh Paint...Wadda Ya think?!
- Aftermarket intake for the 215
- 350 doesn't like wide open throttle
- more power for my 403 smallblock
- I found my problem
- Ram Air Hood...vendor problems!
- 307/350 swap, vacuum nightmare!! (77' rocket)
- Priming the oil pump
- Hooker problems
- Lets start over
- No Vacuam
- Need help with my build.. What to do?
- 307 engines
- 307 engine information needed
- TCS solenoid
- 215 main bearing caps
- 350 Rebuild with problems
- 324 rocket part numbers required.
- edebrock peformer or performer rpm?
- Looking for help/answers for this intake
- Fumes
- 215 exaust question
- Head Bolts
- Looking for 330 crank
- 65 F-85 Newbie with a newbie engine question
- Exhaust bumps
- What intake
- 330 HEADS ON A 75 350
- headers
- What were the best flowing 350 heads?
- lookin for a good set of 350 olds heads
- Please excuse my question but...
- Move engine to drop transmission pan?
- OH NO !
- Should I get this?
- Hesitation question
- 350 rebuild help
- rocker arms
- Spark plugs and pinging
- Anyone know what this block number is??
- Would 70 SBO 350 heads fit on a 72 SBO 350?
- oil pan gasket
- heater control valve
- MECH CAM ADJUSTMENT'S
- colors/decals
- Is a Q-jet from a 455 different for a 350
- Just wondering....
- 350 carb ?
- Who has hopped up a 324?
- ? for 324 Guru's Wheres the mechanical adv
- Carb confusion...
- lunniti cam/65 330
- Correct head gasket
- slight mistake!
- engines info
- 65 330 rear main seal
- most likely an easy question for you gents
- lifters
- HEADERS
- Compression ratio and deck blocking
- This is the world's most expensive and fastest production car ever made
- carb swaping help
- 1963 F-85 looking to swap 327/400
- cleaning block head gasket surface
- BIG SIX
- backfire
- hooking up a sunpro oil gauge
- help
- 9.5.1 comp ratio
- streetable cam???
- Alternator wiring question
- engine color
- Stranger needs advice
- 455 in a 65 cut
- Nobody be mad at me!
- Heat shield for carb.that dumps fuel.
- High Compression Pistions for 350?
- voltage regulator
- Thornton manifolds
- what size carburetor?
- Refreshments for my 68 350
- shimming rocker arm pedestals
- 330 help
- Distributor question
- 371. What's it worth
- Should I have my heads rebuilt?
- clutch fan swap?
- What year alternator do I need?
- Holley Help
- 68 Cutlass 350
- 371 stuck. Engine swap
- 350/350 in a 65 cutlass
- 69 block, 73(?) heads, what gas
- ?350 heads on a 330
- oil pan question
- 307 color
- 455 cam in a 307
- Need the p/n for a dipstick tube
- pulley interchangibilty for 324 with air/steer.
- Blue Devil Coolant sealer
- Urgent help needed on 403 crank!!
- using motor oil for a diesel engine in a gasoline engine
- Valvetrain
- rocker arm question
- Electric Fuel Pump??
- 65 cutlass 330 issues
- 71 350 build spec's
- Creativity at it's finest
- Roller rockers with non roller lifters
- conversion
- Choosing the right cam for 350 rocket
- Another issue
- idle mixture
- Vacuum line layout for '54 Olds
- Aaaarrgh! Overheating...
- Exhaust manifold gaskets
- 350 upgrade
- 350/455 engines for a good home
- '73 EGR valve
- Has anybody used a 350 DX block?
- 1966 330 help
- Cam Selection for a HC 350
- vaccuum advance position
- Kinda bummed out
- valve spring lift
- 350 olds into a 59 super 88
- hard to start cutlass supreme
- timing
- Hedder fitment problem.
- 371 performance
- 70 olds 350 burning oil
- Ram Rod 350
- Building a Small block
- 1968 Olds 350 Rocket redline
- 350 head gaskets
- Timing pointer
- HEADER POBLEM holding up my car completion
- update
- Iron intake on 307?
- intake swap
- Well, Here it is!
- Vacuum line diagram
- rough idle
- Heater
- Another Timing Question
- Loss of power
- running lean
- Fix for Edelbrock Clearance Problem
- 70w-31 intake
- 77cc Cylinder Heads
- Wiper/washer pump
- Compressed air from oil filler tube
- '72 air cleaner
- 71 cutlass small block
- Head Identification question..
- Radiator Question
- 45 degree cam in 350 ?
- carb problem
- Unknown antifreeze leak
- Fan shroud
- Car wants to stall when in gear and idling
- Exhaust Leak
