need help
Old Jan 29, 2009 | 03:17 PM
Danielle's 71's Avatar
ya'll come back now....
need help
im new to this site i know i have a rocket 350 but where else can i find out info about this motor...casting numbers are 39558
Old Jan 29, 2009 | 03:26 PM
Bluevista's Avatar
Registered
Welcome. Do you mean #395558? that would be a '73,'74 350 according to the FAQ.
http://oldsjunction.classicoldsmobil...blk.htm#Blocks
Old Jan 30, 2009 | 06:01 AM
Oldsguy's Avatar
Past Administrator
Welcome to our site. Do you also have a car? Or just an engine?
Old Jan 30, 2009 | 06:31 AM
i also have a car and yes i meant 395558...sorry.i was told it was a 70 and some facts i looked at said that also...
Old Jan 30, 2009 | 07:00 AM
X2
Old Jan 30, 2009 | 07:30 AM
Oldsguy's Avatar
Past Administrator
So the engine is newer than the car according to the id number. Not a big deal, may have been replaced by a dealership early on in the car's life.
Old Jan 30, 2009 | 07:36 AM
so are all rockets arent big blocks?
Old Jan 30, 2009 | 07:47 AM
Nope not in Olds speak, but compared to a Honda you would say Yes they are.
But the 350 is a great motor capable of all kind of cool things. It lacks some of the torque of the Big Blocks but don't sell it short by any means.
What kind of car is the motor in?
Does it have a 350 tranny with it?
Old Jan 30, 2009 | 09:55 AM
all i know so far is that is has the small block 350 and as far a trans go i have know idea...is there any way to find out how much power it used to have?
Old Jan 30, 2009 | 10:02 AM
Oldsguy's Avatar
Past Administrator
I think the factory specs were in the high 200s for the 2bbl equipped, maybe 20 hp higher for the 4bbl one. But those numbers really don't mean a lot. I have a reference at home I can look it up for you. 2bbl or 4bbl?
Old Jan 30, 2009 | 10:11 AM
im not really sure as to what it is....
Old Jan 30, 2009 | 10:13 AM
Oldsguy's Avatar
Past Administrator
Take off the air cleaner housing and measure the "hole" in the middle.
Old Jan 30, 2009 | 11:57 AM
This is an air clear. [could be red I forget] It is attached with one wing nut so not tools are needed.
Old Feb 1, 2009 | 05:17 PM
ok i found out its a 4bbl
Old Feb 1, 2009 | 06:45 PM
That 350 block casting was used from 1968-1976. The FAQ is wrong, which is why we've fixed it in the Wiki. The VIN derivative on the driver's side of the block will tell the exact year.
Old Feb 6, 2009 | 06:05 AM
88 coupe's Avatar
Junior Member
All Olds V8s (except 215) from '49 into the '70s, were called "Rockets".
Except for advertising, the term is useless.
Norm
Old Feb 6, 2009 | 12:40 PM
Oldsguy's Avatar
Past Administrator
Norm that is true, but I still take pride in referring to my engines as rockets. It's kind of fun.
Old Feb 6, 2009 | 02:17 PM
And the 215 was called the "Rockette", so at least someone in the marketing department had a sense of humor.
Old Feb 6, 2009 | 07:38 PM
jensenracing77's Avatar
even in the 90s, the quad 4 was called Oldsmobile's smallest rockets. your car is a great find. i see a 57 98 running around my town from time to time. trying to locate him but had no luck so far.
Old Feb 8, 2009 | 06:28 PM
well a 455 blot up to my car with eas?
meoff
Site Help
Aug 29, 2013 12:15 PM
coppercutlass
Mar 1, 2013 07:33 AM
cutlassclay
May 11, 2012 06:31 AM
MJAKS462
Apr 15, 2010 02:34 PM
silverriff
Mar 24, 2010 06:36 PM
