350 SB Heads
Old Jan 9, 2009 | 12:57 PM
Cardinal's Avatar
New 350 Guy
350 SB Heads
I'm just getting back into something I think is fun. I got a 73 350 #8 heads cheap. Run of the mill stuff. I want to bring it back a little better than when it was built. Would a set of 5A heads be something to consider as a start to increase comp (.93 increase) flat top pistons, mild cam. I'm looking for 300 hp in the end.
Cardinal
Old Jan 9, 2009 | 02:27 PM
dan2286's Avatar
Are you talking about 5A heads from a 307 or 5 heads from a 350?
Old Jan 10, 2009 | 04:46 AM
Cardinal's Avatar
New 350 Guy
At this time its 5A heads from a 80's 307. I am in to advice. I saw some on Ebay and was just wondering.
Old Jan 10, 2009 | 04:59 AM
Cardinal's Avatar
New 350 Guy
Just a little more info. The VIN derivitive on the block is 33W134707. The "W" is confusing to me. A realiable source sugests the "W" is a miss aligned "M" . I have never seen a "M" so I don't know what it looks like upside down. The oil filler tube is 3864688 may not be orig. crank is 393654 (74) and the julian date code is 172, so I'm thinking late 73 early 74.
I do think this site is a MUST for anyone who into anything Olds
Old Jan 10, 2009 | 07:29 AM
The second "3" in the VIN derivative also indicates the 1973 model year. The "M" used in the VIN derivative stamp has parallel sides, so if it really is an upside down "M", the outboard legs will be parallel. A "W" has outboard legs that are splayed.
Old Jan 10, 2009 | 07:45 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
5A heads from a 307 have 1/2'' bolts
#8's have 7/16''
Old Jan 10, 2009 | 11:14 AM
Cardinal's Avatar
New 350 Guy
The legs are definatly splayed so a Willow Run station wagon engine?
lunaboy
Sep 24, 2018 10:15 AM
olds4life
Dec 25, 2012 12:56 AM
gearheads78
Nov 10, 2009 09:31 PM
dharlett
Sep 23, 2009 03:30 PM
shaks 442 clone
Oct 18, 2008 09:41 AM
