sonic check
sonic check
Saw an interesting thread over at v8buick:
http://www.v8buick.com/showthread.php?p=1356801
Got to thinking, how does this apply to olds engines? Is sonic checking a "must" when boring an olds engine 0.010", 0.020", or 0.030" over? What do you guys think?
There's rumor that some GM casting forms are better than others. On the back of your Olds block there's a raised letter casting. Usually F1 or F2 etc. etc.
I believe those are the different factory casting forms used to cast the engine blocks.
Some are believed to be cast more "on center" than others, allowing more "meat" to be left over on the cylinder walls after a lot of over boring.
There aren't enough people out there sonic checking all of these different blocks and forms and posting the data, however.
Steve-O on this site might be able to elaborate more, as his machinist sonic checks his blocks now after he had a .060 stock block crack on him after 3 years of running 9 sec quarter miles with it. I'm sure he could tell you what "F" series the one he broke was.
It is a myth that has never been substantiated. ALL Olds blocks have "F" numbers on the back. The 65-67 425 blocks, for example, also run from F0 through F5 or 6. Do you really think that Olds reduced the nickel content in those blocks by 1967 then increased it again in the 455s in 1968? Not a chance. The "F" numbers refer to casting core variations or lots, in my opinion.
Although Oldsmobile blocks do have a much higher nickel content in them than a Chebby block. It's obvious from looking at cylinder walls after the same amount of miles driven.
In the v8buick post it says sonic checking should be around 75 dollars. My biggest problem with sonic checking was that I called around and the only person I could find that does it charges a ridiculous 250 dollars.
Yup.
The people that actually invest in a sonic checker usually have a long wait in that tool finally paying for itself. It seems they would like to speed up that process with quotes like that.
Seriously, how often does someone get a customer that wants a sonic check?
I'll bet not very often at all.
We do about one a month, maybe less. It takes a couple of hours at most. We charge $90. What engine are you working on? I have never heard of a 350 that had issues going to 4.125" or a BBO going to 4.185". 403s are supposedly thin-walled, but I have experience with them.
I have never done or heard of using a later windowed 350, but nobody I know that has done it to an older 350 block has had any problems. One guy at ROP bored his out to 4.185"!! I am not recommending that. The reason you go .068 to 4.125" is then you can use the plethora of 400 SBC pistons that are available instead of the very few options for Oldsmobile engines.
The pins on the SBC are .920, vs .980 on the Olds, so the pins are lighter. Quite a few pin heights are available in the SBC 400 piston. You can offset grind the crank and use the 2" rod bore and get more cubes and stroke. Or, use the 1.890" Honda bore and add even more.Here are a few combo, there are a bunch,
CI Bore stroke p/h piston weight rod length rod/pin weights
375 4.125 3.510 1.560 485g 6.00 535g 118g
375 4.125 3.510 1.425 466g 6.125 540g 118g
387 4.125 3.620 1.260 451g 6.250 545g 118g
It was a 1970 F1 block, it cracked right down the middle of the #4 main web and went up between #5 and 7 cylinders...
It was .133 thick there after the .060 overbore...
J your old "Fragged 455" 1972 F block will be going up there soon to be checked... It might just be the thickest Olds block ever cast
Im also gonna check a later Fa block and a 66 425 D block, the best one will be the heart of the rebuild
Thankfully the Olds block is quite a bit thicker than a Buick block
fast67vellen2o
March 31st, 2018 02:30 PM
