carb swaping help
carb swaping help
My neighbor has a bone stock 68 Cutlass with a 350 2 barrel carb. He has recently just ordered a 4 bl Rochester carb to go with a used stock 4 bl intake manifold. He has yet to install since he needs to hot tank the intake. My thinking is that he will need new linkage and fuel lines. Is this correct? Are there any additional parts he would need? By adding just the intake and 4 bl, what kind of power increase would that net? Thanks for any info you can give me.
you/he won't gain a lot from a 2-bbl. to 4-bbl. swap, assuming the carb. is calibrated for the application. in '68, the factory 4-bbl. equipped cars had an advertised 10.25:1 compression ratio vs. the 2-bbls. advertised 9:1 compression ratio. the distributor advance curve is a little different and the 4-bbls. had bigger valves.
the linkage and fuel line(to the carb.) is bent differently. and iirc, the 4-bbl. uses a different fuel pump.
bill
bill
bill
bill
Bill and Joe, thanks for the replies. I know he was hoping to make the car a little more powerful. He'll be happy to know he should be able to bolt the swap right in without any additional parts. Is a distributor recurve neccessary? Any tuning hints I can pass on to him?
Thanks again.
John
Thanks again.
John
joepenoso
Jul 19, 2013 12:44 PM
