slight mistake!
Old Sep 24, 2008 | 07:37 PM
Gary Lagacy's Avatar
Question slight mistake!
I have my rebuild all back together and found one slight problem. I apparently did not stall the oil slinger on the crank berfore installing front cover, because it is still sitting on the bench. I have noticed in my Edelbrock instruction guide for the 7800 series timing chain & gears series that you leave the slinger off for model 7820. I installed the 7813. I do not have the harmonic ballancer installed yet. looking in toward the crank it doesn't appear to be any room in there for the slinger. HOW IMPORTANT IS THE OIL SLINGER ON THE FRONT OF THE CRANK??? DO I TARE DOWN THE FRONT COVER AND PUT IT ON AT THIS POINT???
Old Sep 24, 2008 | 07:47 PM
woodie582's Avatar
call edelbrock tech line.
Old Sep 25, 2008 | 05:26 AM
The oil slinger is intended to reduce the flow of oil towards the front seal. Leaving it off will increase the likelyhood of a front seal leak.
OldSchoolMuscle71
Aug 15, 2012 03:22 PM
gthmcty1
May 21, 2012 06:53 AM
72442
Dec 4, 2009 05:43 AM
72442
Nov 27, 2009 11:38 AM
ztim
Nov 10, 2008 12:57 AM
