slight engin smoke
Old Nov 9, 2008 | 02:13 PM
ztim's Avatar
slight engin smoke
After running for a little while, my 307 smokes a little. I can't find any leak or burning hose. It does not have a burning smell but more or less something getting hot. It seems to be coming from down by the transmission fluid fill tube. Any ideas? Thanks.
Old Nov 9, 2008 | 03:09 PM
csstrux's Avatar
I had a 69 Buick skylark the trans cooler line had contacted something down by the bellhousing and wore though, just a pin hole. It did not leak except under pressure, I took the trans out of that car twice before i found that cotten picken line, but by then it had gotten large enough to leak static an I was able to trace the leak. Probably something else, but worth a closer look.
Old Nov 9, 2008 | 05:19 PM
Ice's Avatar
Ice
Valve Cover Gasket
Try seeing if it's Valve Cover Gasket
Old Nov 10, 2008 | 12:57 AM
dan2286's Avatar
Do you see any kind kind of fluid residue? Is anything leaking on the exhaust?
Del70
Sep 2, 2014 02:33 PM
gthmcty1
May 21, 2012 06:53 AM
72442
Nov 27, 2009 11:38 AM
venividivici53
May 7, 2009 05:48 PM
Gary Lagacy
Sep 25, 2008 05:26 AM
