Fumes
Fumes
Hello all,
Im a bit confused as to whats going on with my car.I posted something similar to this before but would like more insight if possible.My problem is I keep smelling exhaust fumes in my vehicle when I drive.It's making me upset (and dizzy)!!!
I have covered every hole in the firewall that you can think of.I also bought a new evap canister and filter.My next guess is the engine I installed in it.
Can that be causing excess fumes
HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
.I have covered every hole in the firewall that you can think of.I also bought a new evap canister and filter.My next guess is the engine I installed in it.
What type of engine did you install in it? If it is just a different Olds engine I wouldn't think it would cause an exhaust smell unless it has a specific problem. How far back do your tailpipes go? If you have them cut off after the mufflers you might be getting some blow back from under the car...
The only other thing I could think of is if the engine just needs a tune up.
fumes
I have a 72 olds 350 rocket in it.My pipes go back behind the rear wheels and I put in new plugs when i installed the engine about 6 months ago.I plan on changing the wires and cap and rotor this weekend.That wouldnt cause the smell though,would it?
I'm going get it timed also.I timed it by ear and what i thought was right but i think it might be running to rich.
start looking for exhaust leaks
I timed it by ear
Finally, you might want to get a vacuum gauge to set your idle mixture screws. A tachometer comes in handy too.
I vote for exhaust leaks also. Do a visual/tactile check first with engine off and system cool. Feel for any corroded pipes, especially at curves where moisture/condensation can collect and then look for obvious rust holes.
I have all new exhaust from the headers back. 2.5 inches.I got all new exhaust when I put the motor in.I was going to get under there and look for possible rust holes in the floor. I just installed new carpet and didnt see any when I put it in but maybe I missed.I'll keep you guys updated.
I just installed new weatherstripping on the trunk. I actually have to give it a little slam to get it to close.
Regards,
Fred
