engines info
engines info
i have a 1970 cutlass supreme 350/ 4 barrel. on my build sheet the engine shows a qp, i read a article saying there was a qv,qb, anyone know what a qp stands for any help, thanks.
I just checked mine and mine has the same QP. My trans shows JL. It is a 350 turbo. I'm not sure either. All I know is that the 70 Supreme 350 had 315 horse. By looking at some of the other codes It looks just like random codes they made up???
engine info
i don't know i bought this car from the original owner, had 2 of the same build sheets under the rear seat, the article i read was in muscle machine, the engine in mine should have 310 horse, with the 4 barrell, mine only has 54,000 original mile on it.it said the qb engine had a hotter cam and only 531 were produced that year.
Sounds like a nice car. Your right 310 HP. I just looked at a dealers brochure and it only shows one other 350 with more horse W-31 with 325. Maybe you could order that in the supreme and is the qb engine. Mine also was a one owner. I found 3 build sheets but only one was ledgible. Mine currantly has just over 170,000 and the engine has never been out of the car. Was yours built at the Linden Plant?
Hello, my service manual and online sources show (4) 350 4bbl engine codes. Three are L 74's QV SMT which I believe is the hotter cam mill, a QN for AT wo/ AC, and a OP for AT w/ AC. All three were rated at 310 gross hp which doesn't mean to much, but the manual trans engine with the hotter cam (#393858) should produce more horsepower. The hottest 350 Rocket was the W31.
http://oldsjunction.classicoldsmobil...ofcam.htm#Cams
http://oldsjunction.classicoldsmobil...ofcam.htm#CamsLast edited by 68/70 Cutlass; Sep 24, 2008 at 07:21 PM.
Allan
engine info
mine was sold in phila pa on germantown ave , factory buckets,console,am radio,to the 1st owner, i believe it was built in the same plant, also anyone running hei in these cars, mine runs really good, but would like to switch it over,and does it make a major difference, also what fits in there good, mine is a a/c car,i want to make sure i have clearence with the fire wall, just ordered a quater skin thats getting done,
mine runs really well, doesn't tap,smoke, had the carb rebuilt, but when it was on a scope the gear on the trans shows wear, runs strong,still spins the tire,-peg leg-rear, i figure hei or should go wit a stock distributer with pertronix? don't know what will run better. not gonna do a rebuild yet, it runs that good.
mashbaugh
Sep 17, 2012 08:40 AM
