Has anybody used a 350 DX block?
Old Jul 28, 2008 | 12:02 PM
Redog's Avatar
And what has to be done to use the 350 diesal block?
Can I just take the long blcok and put on the heads and manifold and go. I know that the head bolts need to be 9/16" or drill out the older heads to 9/16" bolts holes. I would also be putting in the Edelbrock 7112 cam to match my current manifold
Can it be done and has anybody done it?
Old Jul 28, 2008 | 12:07 PM
gearheads78's Avatar
car guy
Unless you are looking to make big power with a power adder why bother. Just build an early 350 block.
Old Jul 28, 2008 | 12:22 PM
dan2286's Avatar
http://www.442.com/oldsfaq/ofedsl.ht...elEngineDetail
Check this website out. It has some pretty good info on the diesel engines and what is involved into making it run on gas.
Old Jul 28, 2008 | 02:50 PM
Redog's Avatar
^^ I did already
I just wanted to know if anybody has done it.
I have an early 350 block, I was just looking for a different or cheaper route since Mondello has a new 350 DX block for $1500.
Old Jul 28, 2008 | 03:01 PM
quick86silver
Guest
Posts: n/a
Theres some info on DX Blocks on 78-88olds.com but it doesn't look like anyone has actually done the buildup. Theres a good Mondello article and a few other links.
http://www.78-88olds.com/forum/showthread.php?t=11
Old Jul 28, 2008 | 05:14 PM
car guy
Originally Posted by Redog
^^ I did already
Am I missing something? Why would you pay 1500.00 for a block to save $$ The 350 you have is free. Starting with a new block does not mean it won't need machine work.
Again the only reason to build a DX is to hold to extreme power. A build under 500HP I would not even think about it.
Also you are looking at a min 300.00 to ship a block if not more.
Old Jul 28, 2008 | 05:59 PM
Redog's Avatar
^^ Yeah I guess so.
I was just thinking of everything.
This won't be happening for 2 years anyway
Old Jul 28, 2008 | 06:10 PM
Dapapadon's Avatar
OK, I got to ask where you're going with this? To start by buying a $1500 bare block then having to find a DX crank isn't going to be cheaper. And with the larger main journals engine RPM is going to be reduced compared to a standard 350. A 350 doesn't have the CI/torque to make up for the lose of RPM's as compared to a big block. And I don't think you are planning an exotic build if you're asking the "cheap" question.
So I'm guessing what you are really asking: 'Is starting a 350 build with a 350DX block a good idea?' My opinion, No! Build a standard 350 and it will be cheaper, rev higher & you'll be happier. If you want the best bang (no pun intended) for your bucks, build a 455. If you want the best mild performance small block consider using your 350 crank in a 403.
Just my opinion, Don
Old Jul 28, 2008 | 06:14 PM
Dapapadon's Avatar
Oops! I spent too much time talking about blackberry cobbler.... gearheads78 said about the say thing, with a whole lot less words.
Don
Old Jul 28, 2008 | 06:35 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
If you want a DX, buy one from Dick Miller.
Cheap is negated however if you do.
Old Jul 29, 2008 | 07:41 AM
If you have a DX block build it as a Diesel engine and put it in a 1984 Custom Cruiser. Then you can put farm diesel in it and save a bundle on fuel costs. The cops will never think to check your old station wagon for the red dye.
Old Jul 29, 2008 | 07:58 AM
Warhead's Avatar
You HAVE to move a head locator pin also. Not easy, you have to use the head gasket to locate and drill the hole for the locator pin. Make it straight.
$1500 is WAAAAY too much for one of these things, unless new. I had one of these for sale locally for $300.
I built one years ago, and ran it until I spun a bearing. FUN. The reason they do not like to rev is because of the heavy assed pistons and rods.
The best scenario for this build is to get some #8 heads for it, put in some bigger valves, and hit it with a 350 shot of nitrous between 3500-5500 rpm.
Jim
Old Jul 29, 2008 | 05:54 PM
88 coupe's Avatar
Junior Member
Originally Posted by Warhead
........ WAAAAY too much for one of these things, unless new ........
It's NOS, and it's been for sale for a loooong time.
........ I had one of these for sale locally for $300 ........
I got my DX for free. Didn't take the D block that was offered with it. Didn't know any better at the time.
Original plan was 4.125" x 4" combo. Wasn't happy with the available rod angle choices, so it's on the shelf. If/when I do screw it together, I'll probably go to 4.25" and use a 350 crank.
Norm
Old Jul 29, 2008 | 06:43 PM
car guy
Norm
Norm you feeling OK buddy? I noticed no sarcasm in that post
Old Jul 29, 2008 | 08:11 PM
88 coupe's Avatar
Junior Member
Originally Posted by gearheads78
........ I noticed no sarcasm in that post
No stupidity in the post = No sarcasm in the response.
Norm
Old Jul 29, 2008 | 08:37 PM
raadon
Guest
Posts: n/a
I have the same block will sell for 500.00 350DX .842 lifters new
Old Jul 29, 2008 | 09:10 PM
88 coupe's Avatar
Junior Member
A DX with .842" lifter bores?
Norm
Old Jul 29, 2008 | 09:15 PM
raadon
Guest
Posts: n/a
Norm
yup, the one mondello has should be small lifter too, or it is just a regular production block.
Old Jul 29, 2008 | 10:20 PM
88 coupe's Avatar
Junior Member
Originally Posted by raadon
........ the one mondello has should be small lifter too ........
From here, they look like 921".
........ or it is just a regular production block.
Its a GM diesel short block. He probably snagged a some of the last that came off the line. If so, it would have .921" lifter bores.
What did you think it would be?
Norm
Old Jul 30, 2008 | 05:49 AM
raadon
Guest
Posts: n/a
Looks like .842 lifters to me. They made a few of them. Greg Godon got a few of them from Warren Johnson a couple of years ago. A couple others on ROP had them. I bought this one I have in '95 for $250...so I'd sell it for $500.
Old Jul 30, 2008 | 04:21 PM
88 coupe's Avatar
Junior Member
Its a GM diesel short block ........
........ What did you think it would be? ........
No answer?
........ They made a few of them ........
"DX" castings ('81 and newer) used .921" roller lifters, as opposed to the "D" castings ('80 and earlier) that used .842" flat tappets.
Is yours an exception?
........ Greg Godon got a few of them from Warren Johnson a couple of years ago. A couple others on ROP had them ........
Art Rizzi will be using one of the same, in his Super Pro. Russel Hunt and Bill Trovato have been using them for several years.
However: Those are Batten/Nascar blocks, not to be confused with, "D" and "DX" which are a different casting.
........ I'd sell it for $500.
No doubt.
Norm
Old Jul 30, 2008 | 04:54 PM
raadon
Guest
Posts: n/a
Pretty sure Art has a DX with 2.5" mains with .842 lifters. And thick straight oil pan rail. Somebody had one on the other day that was a diesel "D" block that had .921 lifters. As far as what block I thought Mondello's had would be the same one I have. That is probably the only thing that distinguishes it would be the small lifters. It still has 3" mains. I will sell it because I' think I'm going to buy that 4 bolt aluminum block. (They probably say they never made that either). Bottom line they made many different versions of DX, D, and nascar blocks.
Old Jul 30, 2008 | 05:25 PM
raadon
Guest
Posts: n/a
No doubt.
Norm
Obviously you have no clue how much it costs to bush the lifter bores if you want to run rollers. That alone makes the block a steal.
Old Jul 30, 2008 | 05:38 PM
captjim's Avatar
" However: Those are Batten/Nascar blocks, not to be confused with, "D" and "DX" which are a different casting."
Incorrect, unless Art is mistaken.
If this is the engine that is being referenced, here are the specs,
http://arrace.com/index.php?option=c...d=53&Itemid=79
That from Arts website. It is a DX block with .842 roller lifters, however it does not say whether they were bushed.
Russels is a Nascar block, here are his specs,
http://72.22.90.30/phpBB2/viewtopic.php?t=759
Old Jul 30, 2008 | 06:43 PM
88 coupe's Avatar
Junior Member
Originally Posted by captjim
........ if this is the engine that is being referenced ........
It is.
........ it does not say whether they were bushed ........
It doesn't have to:
      Norm
      Old Jul 30, 2008 | 06:55 PM
      raadon
      Guest
      Posts: n/a
      Quote:
      Originally Posted by Texascarnut
      ........ I think you are more of an irritant to everyone here, and most certainly not nearly as smart or knowledgeable as you seem to think you are.
      ^^^^^^ I think that pretty much sums up Norm. Put it this way Bullwinkle, I have a DX block with .842 lifters, and can prove it...how much money do have to wager on it??? You aren't as smart as you think you are.
      Old Jul 30, 2008 | 07:16 PM
      88 coupe's Avatar
      Junior Member
      Obviously you have no clue how much it costs ........
      Obviously.
      I specifically chose the "DX" so I could use .921" lifters.
      ........ to bush the lifter bores if you want to run rollers ........
      "DX" came with rollers, no machining needed.
      If I wanted to use .842" lifters, I would have picked the "D" block. The cost of the unnecessary machine work would probably buy a lot of beer
      ........ That alone makes the block a steal.
      Yes, it does.
      If I was selling a "bushed DX" block, I would describe it accurately in my opening post, in order to justify the price.
      Norm
      Old Jul 30, 2008 | 07:23 PM
      raadon
      Guest
      Posts: n/a
      Norm
      That's because it isn't bushed...are you that dense? Like I said how much money you got, you seem to think you know everything? Show everybody on the board how much of a bigshot know it all you are and put some money on it...I got $5000 cash says I not only have one but there are many more...Come on Norm...put your money where your mouth is.
      Old Jul 30, 2008 | 07:30 PM
      88 coupe's Avatar
      Junior Member
      ........ I think that pretty much sums up Norm. Put it this way Bullwinkle ........
      Having a little trouble keeping up with a simple technical discussion, are we?
      ........ I have a DX block with .842 lifters ........
      Did anyone say anything different?
      ........ and can prove it...how much money do have to wager on it? ........
      This reaction, looks like a textbook example of a BS artist who has been backed into a corner.
      ........ You aren't as smart as you think you are.
      Actually, I already know that.
      Norm
      Old Jul 30, 2008 | 07:36 PM
      raadon
      Guest
      Posts: n/a
      Wanting to prove you wrong and I'm the one backed into a corner...I can lower the amount so you can afford it. I'm sorry you are clueless...call Art and he will set you straight. His block is a DX with 2.5" mains (no spacers) and .842 lifter bores "no bushings" you can stick your head in the sand if you want but you're wrong...admit it and be a man.
      Old Jul 30, 2008 | 07:49 PM
        #31
      88 coupe's Avatar
      Junior Member
      That's because it isn't bushed...are you that dense? ........
      Not dense. Simply stepped into your trap. It will not happen again.
      ........ I not only have one but there are many more ........
      The more there are, the easier it will be for you to document their existence.
      An inquiry to Chris Witt (Octania on ROP) would be a good place to start.
      Norm
      Old Jul 30, 2008 | 09:07 PM
        #32
      88 coupe's Avatar
      Junior Member
      Wanting to prove you wrong ........
      BS artists are obsessed with "proving" who is right, and who is wrong. It is an "ego" thing that is counter productive.
      If you have "proof", show it.
      ........ and I'm the one backed into a corner ........
      Yes, you are.
      Your insults/name calling/flames, are not "proof" of anything. To the contrary, they are the favored tools of a cornered BS artist.
      ........ I can lower the amount so you can afford it ........
      The kind of childish BS that belongs on a "ricer forum".
      ........ I'm sorry you are clueless ........
      So am I. I will be less so, when you show your documentation.
      ........ call Art and he will set you straight ........
      Not the way it works. You are the one going against common knowledge, the burden of "proof" is on you.
      ........ His block is a DX with 2.5" mains (no spacers) and .842 lifter bores "no bushings" you can stick your head in the sand if you want but you're wrong ........
      So far, the only support you have, are your own unsubstantiated statements.
      What you, and the other trolls do not realize, is that there are more than a few CO members, who will correct my technical errors, in a heartbeat. Did you notice how quick captjim stepped up?
      You can "wager" whatever amount you would like, that if I made a technical error, anywhere in this thread, everyone would have known about it, in short order.
      You can donate your loss, to your favorite charity.
      ........ admit it and be a man.
      I make it a practice to acknowledge my mistakes as soon as I am aware of them.
      If/when you have anything of substance, post it. If you do not have anything, you can continue your pizzing contest by yourself.
      Norm
      Old Jul 31, 2008 | 06:26 AM
        #33
      raadon
      Guest
      Posts: n/a
      Bullwinkle, I am willing to wager money because you are calling me a liar...you're the one who started with the smart assed comments and name calling. There has to be somebody on this forum in the Lansing, MI. They are more than welcome to bring a .842 lifter and fit it to this unbushed block and make an *** out of you. Maybe I should link this to ROP and let them vultures come down and pick you to pieces. You are a complete tool.
      Old Jul 31, 2008 | 09:44 AM
        #34
      raadon
      Guest
      Posts: n/a
      http://www.realoldspower.com/phpBB2/...ic.php?t=49502
      Old Aug 1, 2008 | 02:20 AM
        #35
      88 coupe's Avatar
      Junior Member
      http://72.22.90.30/phpBB2/viewtopic.php?p=480564#480564
      Originally Posted by On ROP, by 88 Coupe
      Hi Guys,
      Originally Posted by Rocket science
      John the block that Art,you and Russell have are 1st generation HP race blocks ........
      I recently saw one of these blocks for sale, for $500. He said "new" so I would assume NOS.
      Should I grab it while I can?
      Norm
      Old Aug 1, 2008 | 04:34 AM
        #36
      raadon
      Guest
      Posts: n/a
      When Greg said 1st gen. hp block he is talking about the 2.5" main, wide pan rail block. I'm not sure what mine would be classified as seeing it has a regular pan rail and 3" mains. Like the one Russel Hunt is referring too, when he said he used to bracket race. Probably just considered early DX block.
      Old Aug 1, 2008 | 05:04 AM
        #37
      Oldsguy's Avatar
      Past Administrator
      The last two posts are examples of factual, informative, and objective statements without name-calling or flaming. Let's keep it that way gentlemen.
      Old Aug 1, 2008 | 05:17 AM
        #38
      raadon
      Guest
      Posts: n/a
      With all due respect, I don't appreciate being called a liar. I never come to this site. I was just looking for some trim pieces for an antique car. I seen a post about a 350 DX so I read it. I offered this block so the guy didn't get ripped by Mondollar. Then somebody jumps in an tells me there is no such thing and I'm misrepresenting what I'm selling. Like I have to prove it exists? I know it exists I GOT THE THING! Prove it doesn't...don't call me a liar and put the burden of proof on me. Come on people grow up!
      Old Aug 1, 2008 | 06:59 AM
        #39
      Oldsguy's Avatar
      Past Administrator
      He disagreed with you, he didn't call you a liar. Three possibilities, you are right, he is right, or based upon circumstances and experiences both of you made correct statements to the best of your knowledge and there is a disagreement. No name calling or proof is required, let the statements stand.
      Old Aug 1, 2008 | 10:51 AM
        #40
      Yellow bellied jack-a-napes and scallowags are not very amiable.
