Cam 180 out?
Old Dec 26, 2008 | 07:47 PM
mp71conv's Avatar
Cam 180 out?
I Have a 71 350 that I am rebuilding.
I have a lunati voodoo cam
lunati timing chain set
I lined the marks up like normal instal of the timing chain.
After checking the no1 .pusrod sizes. I relized the it was on the exhaust stoke.
When the cam is at zero lift on the no1 cyl the dot on the gear
is at 12 oclock.
I am lost.
I looked at the old cam and gear and they are 180 different.
Has anyone installed their cams or has anyone seen this.
Old Dec 26, 2008 | 08:44 PM
mp71conv's Avatar
Ok I just checked it again and with the marks lined up.
It is at TDC on the comp stoke at cyl no 6.
Old Dec 26, 2008 | 09:30 PM
dan2286's Avatar
Recently someone mentioned that a lot of people get confused when they are lining up the dots on an Olds engine.
I guess Olds is set up to have the dots lined up on the exhaust stroke on the #1 cyl.
Old Dec 27, 2008 | 05:50 AM
Since the cam turns at half the crank speed, it will be properly aligned twice - once when the dots on the two gears are facing each other (crank at 12:00 and cam at 6:00) and again when both dots are at 12:00. You just need to install the distributor so that the No. 1 plug fires when that cylinder is on compression.
grmchne78
Jun 25, 2015 06:23 PM
Oldsmaniac
Jun 20, 2014 05:44 AM
Uncle Hulka
Mar 12, 2014 03:41 PM
Ablast
Jun 9, 2013 10:57 AM
StickW31
Sep 9, 2012 06:57 AM
