Correct head gasket
Old Sep 25, 2008 | 12:29 PM
77 oldsMAbrotha's Avatar
Toliver
Correct head gasket
After a year I finally rescued my #7 heads from the machine shop now they are ready to be sat atop the 77 block. My question is, "do I use the 77 head gasket or the 71? If I had to guess I'd chose 71, but this is no time to make ASS_umptions. And is there a brand that is preferred over others?
Thanks to everyone who reply
Old Sep 25, 2008 | 03:23 PM
I was ready to say they were the same, but I checked and they're not. Fel Pro 8171-PT1 fits all Olds V8s 330-455 through 1976. Fel Pro 8506PT fits 350s for 1977-1980. They look the same in the pictures (for what that's worth) so the only difference I can imagine is the holes for the head bolts. If that's true, you'll want to use the 77-80 gaskets due to the larger 1/2" head bolts in you 77 block. You DID have the holes in the early heads enlarged, didn't you?
Old Sep 25, 2008 | 09:56 PM
88 coupe's Avatar
Junior Member
........ "do I use the 77 head gasket or the 71 ........
Always use the gasket for the block.
Norm
Old Sep 26, 2008 | 06:50 AM
Toliver
Yes, heads were drill for 1/2" bolts...little something learned @_"CLASSICOLDSMOBILE.COM"So, it's the gasket for the 77, got it!
Thanks again!
Bobac455
Dec 4, 2013 09:23 AM
aussiemobile
Feb 15, 2013 07:31 AM
harry k
Nov 21, 2012 08:54 AM
dallasite21
Jun 20, 2010 05:37 AM
Sixoh
Aug 8, 2006 05:11 AM
