- what to expect from 1977 Olds 350 cutlass engine
- Edelbrock 1411 too much carb?
- How to Choose the Best Carburetor ?
- Head bolts and studs...where do they go???
- 2 barrel carb rebuild?
- 215 V8 main seal(s) question
- grannys back on her feet....
- heads,Ignition, and Intake install
- part number for replacement water pump hardware?
- advice on bringing old motor back to life
- 67 F 85 specs and engine data
- Manifold Removal
- Unk Vac Line
- Total Timing SBO
- Flywheel for Olds 350 Diesel
- spark plug wires issues
- Gasket questions
- 350 pulley questions
- Place to buy 330 rebuilt kit.
- 350 oil pump?
- need alternator bracket for 1972 cutlass
- HELP! Crack by valve cover
- Fuel pump mounting question
- Rocket 350 sluggish
- #2 heads rocker studs
- diagnose my knocking noise
- yet another fuel question .
- Edelbrock 1406 carb
- Am I bored or what?
- 350 id
- little carb issue with my new 650 dp holley
- Lookin for a new engine
- Bubbles in the radiator!
- Anyone running an Erson TQ40 cam?
- 72 350 rods?
- Sealing/gasket help
- Carb troubles
- 72 Cutlass dies while driving
- What type of puller for the crank gear?
- 350 backfiring through carb on heavy accel.
- rather productive day
- accessory mounting
- factory air valve
- Thrust bearing crush
- Fuel Infection
- Comp Cams magnum 280H
- Q-jet hot idle compesator
- Carburetor Troubles
- 1966 Cutlass lifter diameter?
- broken exhaust bolt
- 69 350ci quadrajet
- Holley Carb on Edelbrock Intake
- Intake manifold choices
- 68 Cutlass 350 Rocket Lifters Chattering?
- 2 to 4 BBl conversion
- Holley 4160 to 4150
- DIY 350 on a budget
- 1968 Olds Cutlass S Thermostat Housing
- Olds 350 Newbie budget build
- what pulleys are these????
- Heat Riser Valve 371
- 1967 cutlass 330 4bbl
- 61 F85 Oil pan Gasket
- Carb suggestions?
- Need an Olds engine builder in Indy
- swap meet 350 build.
- 72 350 Rocket w/4 bbl
- water methanol injection
- Olds 350 Alternator Bracket Question
- Carburetor Recommendations
- How hot is too hot?
- Charcoal Canister Leaking Fuel?
- Questions about identifying a small block
- Blowback
- 70 Supreme in need of help
- 350 repair
- SBO Rear Main Seal
- w31/ramrod heads
- Cam Bolt to Timing Cover Clearance
- 68 Cutlass 350 Rocket idling rough lately
- 403 into mid '70s X car
- Exhaust crossover
- stall question
- HV water pump
- small block.with nitrous
- Stock 350
- 69 350 question
- Push Rod Length Intake vs exhaust
- Distributor won't come out? 1970 350
- Engine stalling when hot
- Throttle linkage problem
- Lifter noise on my 371
- Got my 65 started.
- Questions about 2bbl to 4bbl and putting in 200-4R
- 350 water pump
- Which 350?
- Rocker Binding on stud base
- carb stumbling under part throttle; vacuum prob?
- small block or big block? you tell me....
- carb question
- Thermal vacuum switch
- 1964 cutlass 4 brl air cleaner info
- First Time Degreeing Cam
- 350/Edelbrock Owners - Chime in.
- Alternator Bracket
- fuel line / filters
- 350 apart, interesting observations
- Removing old head gasket
- 383 stroker
- 69 350 build
- 350 Afermarket Intake Manifold Bolts
- Harm. Balancer recommedations...
- 2 part rebuild on my 1970 350 50k original mile motor
- Blower kit
- 73 350 and #5 heads
- more engine pics in my 68 almost there
- underhood question heater hose related
- Distributor?
- cheap performance parts or my 330 and will the 350 parts fit
- one new engine photo
- engine photo updates...
- Ported Vacuum Switch
- HEI Conversion.
- Gaskets
- 63 F-85 swap kit
- Lifter noise
- Source for Gasket set? Heater core?
- Where do I begin?
- another spun bearing?
- Winter project - heads, cam and converter
- need help with changing headers
- Oh man, me and my luck...
- 350 Head Question
- Will Mondello Edelbrock Aluminum Heads help my Olds 350 Perform Better?
- quick disconnect starter wiring harness
- Name the Quadrajet!
- dating the engine
- 3" exhaust with stock manifolds?
- valve cover gasket question
- 1964 jetstar 88 rad hoses
- timing marks on 86 307
- SBO Intake Weight ?
- ac/AIR pump belt removed
- 2-bbl to 4-bbl. swap. Thoughts?
- Looking for headers
- Thermac air sensor
- Not Paying Attention to Detail!
- 67 330 supreme convertible engine question
- What's the difference between Low and High compression 330?
- hesitation at WOT
- 351c 1.73 roller rockers
- Edelbrock 2812 Victor Olds 350-403 Intake Manifold
- Leaking valve covers
- olds 350 w/ #4 330 heads on it
- #5 heads vs. #7a
- ?Any good olds engine shops in Los Angeles?
- need help timing olds 350
- Fuel Pressure 1970 Cutlass Sumpreme 350
- bad egr valve or solenoid
- 1983 Delta 88 RoyaleBad EGR valve or solenoid?
- Smog 307 7A heads
- Who ca lift thier front wheels off the ground?
- 67 330 compatibility ??
- 350 engine rebuild question
- Radiator bushing question
- Installing 2GC - Questions.
- Just wondering
- engine color ?
- Quadrajet aircleaner on edelbrock 1406?
- confused??
- Potential New parts for the SBO
- 330 block or 350 block?
- SBO heads 7a vs. #3
- Headers 77 cutlass supreme 350
- carb floats
- intake manifold swap - perf rpm or stock cast iron?
- 307 rebuild
- 403 olds exhust problem
- Growling/rumbling sound from the front of the motor
- 330 rebuild
- What has happened to these pistons?? 215 V8
- Sroked Olds 215 Anyone?
- Upgrading Intake and Carb
- curving a distributor
- 2GC rebuild woes.
- grinding down air bumps
- valve adjustment/lifter problem
- 1972 SBO 350 combo
- Got my engine back!!
- Future 350 Build Questions
- Dust Shield?
- 324/371 Question
- Popping when decelerating
- new exhaust manifolds
- 1968 Olds Cutlass S Headers
- Help! What pump to carb line do I need?
- 68 Cutlass Supreme radiator options
- Where to find/buy carb rebuild parts NOT in the kit.
- 403 w/#8 350 heads
- quadrajet mixture screws
- valves stuck in heads.. need sugestions
- picking a good cam
- It's getting there!
- 215 engine pushrod length
- oil splash shield
- 303/324/371 question
- big valved #6 heads
- Air Cleaner Assembly
- 1956 olds engine 3 speed lasalle
- 72 350 rebuild
- 86 Cutlass won't stay running, Carb problem?
- Opinions on My Airhorn
- WIW # 5 heads 4 bbl aluminum intake and iron. What are they worth?
- 1972 olds rocket 350
- 69 Olds 350 ideas
- What heads should I use?
- throttle valve cable th350
- TH350 tail shaft
- mr gasket head gaskets
- PCV Valve Grommet Removal
- Olds powered 72 GMC p/u
- cutlass has been cutting off
- Where do I get Vacuum On My 307?
- How common is a cracked EGR base?
- 403 overbore conundrum
- Need some HEI Help!
- point gap spec for 72 350
- 69 350 3bbl questions
- 2.000/1.625 w/ 4.740" OAL ???
- Do I really NEED the EGR?
- Remote oil filter adapter
- pulleys not lining up on 350
- '72 7A head volume
- carb
- 69 Cutlass AC car Vacuum lines
- I love my 73 88...Part 2. Intake and carb questions.
- Rochester 2GC questions
- 72 Cutlass Died
- pistons
- sbo stroker piston
- Out with the old!
- metal in oil
- sbo valve swapping
- Carb or TBI -- Which is Better?
- Choke question
- Orig iron intake - How far can you go ?
- what combos is everyone running in the 13/14 second
- Weight of engine
- 350 rocket a bit tight
