big valved #6 heads
Old Nov 1, 2011 | 07:46 PM
import extermination's Avatar
big valved #6 heads
Just picked up a set of big valved #6 heads
On olds faq i see it says they are int. 1.995 ext. 1.624
Where can i get a set of these?
Or are these numbers incorrect?
Thanks again guys
Old Nov 2, 2011 | 05:23 AM
Indy_68_S's Avatar
I'm not sure what you mean....
If you have 'big valved' #6's, what are you looking for ?
Old Nov 2, 2011 | 06:05 AM
What is the actual size of the valve 1.995 or 2.000... Or does that 0.005 difference not matter?
Old Nov 2, 2011 | 06:30 AM
Indy_68_S's Avatar
I think the 'official' W-31 sizes are 1.995"/1.624", but many go to the more common BBO sizes of 2.000"/1.625" (& some go even bigger!).... I am doing the 2.000/1.625 setup now...
More info here...
https://classicoldsmobile.com/forums...tml#post333941
Old Nov 2, 2011 | 03:13 PM
joesw31's Avatar
The valves are not an exact size, but have a range that will be listed in the the GM repair book. Most parts have tolerances with a min. and max.
Are you looking for W-31 heads?
Old Nov 2, 2011 | 06:18 PM
I have w31 heads that need a rebuild. Trying to get all the parts. Cant seem to find propper valves anywhere
lunaboy
Dec 16, 2014 04:06 AM
Kidcutty
Mar 10, 2010 06:08 AM
olds4life
Feb 9, 2010 08:48 AM
WEBBISH
Nov 23, 2008 06:08 PM
59-59-59
May 19, 2008 07:46 PM
