Fuel Pressure 1970 Cutlass Sumpreme 350
Old Dec 6, 2011 | 12:28 PM
70Cutlass_408's Avatar
This weekend I got around to installing a Edelbrock Performer RPM intake, Holley 670 Street Avenger, new Carter Muscle car fuel pump and fram inline fuel filter.
When I first fired up the car the fuel pressure was very low almost non existent according to the fuel pressure gauge. It stayed like this all day when I was driving around town.
The next day I fire up the car and checked the fuel pressure gauge and its reading about 5 psi. Could I have a faulty fuel pressure gauge, clogged fuel lines, bad fuel pump?
Thanks,
Old Dec 6, 2011 | 12:40 PM
svnt442's Avatar
5 psi sounds about right. If your pressure was non existent the car wouldn't run. I'd keep an eye on it and see what happens. It may have been stuck from sitting and just took a bit for it to free up.
Old Dec 6, 2011 | 01:03 PM
thanks Randy, the car was sitting for about a month before I decided to work on it this past weekend.
Old Dec 7, 2011 | 05:49 PM
So today i fired up the cutlass and now the fuel pressure guage is reading 3 psi. Any suggestions on what might be causing the sporatic fuel pressure.
thanks,
Old Dec 7, 2011 | 07:09 PM
If the car is running fine, I'd stop looking at the gauge.
Old Dec 7, 2011 | 07:15 PM
coppercutlass's Avatar
Chevy budget Olds powered
x2 with mdchanic. I had a pressure gauge bounce between 5 and 10 all day long but the fuel bowl levels stayed the same drove fine so i left it alone.
Old Dec 8, 2011 | 07:49 AM
Ok thanks guys
Old Dec 19, 2011 | 10:34 AM
I ended up changing the fuel filter and now fuel pressure is reading 6.5 psi all day.
dnmfranco
Nov 14, 2013 05:04 PM
oldsuniversew30
Apr 22, 2013 05:03 PM
pcard
Mar 15, 2013 12:44 PM
foreverolds
Dec 1, 2012 07:07 PM
glord
Jul 21, 2009 11:23 PM
