what pulleys are these????
Old Mar 3, 2012 | 02:16 PM
coppercutlass's Avatar
Chevy budget Olds powered
These came with the engine i recently bought i have no use for them and would like to sell them but dont know if they are worth much or what application. Before i blast them and prime them id like to make sre it's worth my time . If anyone also would like them let me know . They came with a 350 from 69 i assume which is what the block is.
Old Mar 3, 2012 | 02:31 PM
Hey Copper
If they are for a 69, the one on the left might be stamped "KF", part number 399404. If so it's the water pump pulley
The other one looks like the crankshaft pulley - code KC, part number 399405.
Someone's always looking for proper parts for their resto. Like I said though, I'm guessing at what you've got cause you didn't post the stampings on the pulleys.
Old Mar 3, 2012 | 02:37 PM
ill put the stamping up once i blast them before i put primer on them . Im guessing they are 69 pulleys. The block is correct these are the parts that came with the deal . Thank you for the info .
Old Mar 3, 2012 | 04:51 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Those sure look like 80's 307 pulleys. I had a set like that on a 5A 307 vin Y. The small pulley is for the air pump.
Old Mar 3, 2012 | 04:56 PM
That supports my second theory this engine was in a gbody it had a metric plex plate on it .Thanks I'll just probably save the time of cleaning them. I just didn't know if they where pulleys from an early ac car I never seen pulleys like them for an olds but I have never worked on a 80's olds so I would not know lol .
Old Mar 3, 2012 | 05:13 PM
Why not post the stampings just for gicks and shiggles. Someone might be able to give you a positive ID.
Old Mar 3, 2012 | 05:39 PM
Ok I will post them. I won't go back to work on the car till monday afternoon . So I might take a day or two.
Old Mar 3, 2012 | 06:59 PM
I second that they are '80's AIR-equipped parts.
You never know, someone may be looking for them.
Dave Siltman
Jul 24, 2014 02:55 AM
ratsglass29
Nov 23, 2007 07:08 PM
classic_car_guy
Mar 7, 2007 06:04 PM
69deltaconvert
Nov 7, 2006 10:25 AM
TOONLOVESCHERYL
Jul 4, 2006 08:07 AM
