72 350 rods?
Old Mar 14, 2012 | 06:30 PM
Rolds72's Avatar
72 350 rods?
How much can the stock rods take if going with 10:25/1 cr should I replace them and if so with what?
Old Mar 14, 2012 | 06:36 PM
captjim's Avatar
IMO, stck rods are fine to 6,000 rpm and 400 HP. Unless you have a big cam and head work, you should be OK. Just recondition them, replace the bolts, and loosen up the clearance to .0020-.0025. Balance the rotating assembly, too. Very few aftermarket options.
Old Mar 14, 2012 | 06:41 PM
Rolds72's Avatar
I have a 280h cam sp flat tops 7a heads 2.02 1.60 valves 7111 intake 200r4 with 3:73s I'm trying to get this combo togather ind can't find much in the way of rods without donating a kidney and having them made. Will they hold up in this combo?
Old Mar 14, 2012 | 06:47 PM
Nasty455's Avatar
XCELERATIONRULES!
From what I've read,all olds rods are forged...but they are soft.
I would invest in a new set...
http://www.amazon.com/Eagle-Specialt.../dp/B002R66G4E
Old Mar 14, 2012 | 07:12 PM
cutlassefi's Avatar
Those are big block rods. Stock rods for this application are fine. Use a light piston and they're even better.
Old Mar 14, 2012 | 07:47 PM
380 Racer's Avatar
I used stock rods in quite a few of my builds. They were winged to 6200 all the time. I sold a few sets of rods to local mud packers in my area a few years back. The hot set up was run 6" Olds rods in their SBCs and used a .030 under bearing and I assume a bushed small end. Because the Olds rods were stronger than the Chubby's and got a 6" rod for a 5.7".
Old Mar 14, 2012 | 07:52 PM
coppercutlass's Avatar
Chevy budget Olds powered
Rolds72 your set up is identical to mine minus the trans. I runa th400. The stock stuff has held for me great even the used cast flat tops.
Old Mar 14, 2012 | 08:01 PM
Nasty455's Avatar
XCELERATIONRULES!
Seems like whenever we try to build something other than a Chevy,we pay out the nose.
Sorry about the above recommendation..ebay lists the 6.7 rod for both the 350 and 455,...I now realize the 350 uses a 6 inch rod.
If you start buying custom rods and pistons,and turning the crank...your better off just going with a 455...more options.
I chose to keep my bottom end stock and just go with a big cam and have some fun.
I have all summer off and I'm going racing...I'm gonna see just how much abuse my 35 year old motor can take.
Old Mar 15, 2012 | 04:43 AM
bigD's Avatar
mondello offers small block rods, $499...
i've often wondered about cryo treating rods, i wonder if that would toughen them up?
Old Mar 15, 2012 | 06:41 AM
FIRST 442's Avatar
Rods
I have a 362 Olds and love my SBO.
Enclosed is a pic of a set of Mondello MR710 rods that have polished beams, shot peened with good bolts for pressed pins.
Next to the MR710 is Mondello's new 6" olds I beam rod good for 850 hp, floating pins.
I searched high and low and those are your only options for a direct fit replacement rod without cutting your crank or using crazy Chebby pistons.
The MR 710 rods are for sale if your interested.
Old Mar 15, 2012 | 06:49 AM
FIRST 442's Avatar
Sorry
Sorry there is no pic as promised.
I guess I am still a newbie here and can not post yet.
There is a pic on Mondello's home page of the new 6" rods.
They are the same price as their MR710 rods $499.
Old Mar 15, 2012 | 09:15 AM
380 Racer's Avatar
Well a few years ago I bought a set of 6" rods from Mondildo, trying to save time. Had to replace 5 bolts, resize two rods and one my machinest couldn't save and had to redo one of the old rods. That is the last thing I will ever buy from them.
Old Mar 15, 2012 | 11:00 AM
Rolds72's Avatar
My buddies have competition rock crawlers and everything is cryoed it does work and it's fairly inexpensive he's had the same third member for 6 years and hasn't come apart yet!!!
Old Mar 15, 2012 | 02:54 PM
captjim's Avatar
"I" beam rods good to 850 HP? Really?? For $500?
Old Mar 15, 2012 | 04:01 PM
jag1886's Avatar
You can also take the stock rods and polish the beams and have them shot peened, that helps a lot. IMHO with the build you have I wouldn't worry.
65cutty
Sep 8, 2010 02:22 AM
Oldwolf
Sep 16, 2009 01:53 PM
cfair
Jul 22, 2009 12:10 AM
Atdog
Feb 14, 2009 06:51 AM
