First Time Degreeing Cam
Old Jan 28, 2012 | 04:22 PM
rkk69olds's Avatar
Need some serious help here.
I bought a degree wheel kit from Summit and am attempting my first degreeing
Getting true TDC was easy enough after I made a piston stop. The heads are off and am now checking the cam. Here's where progress comes to a grinding halt.
First - do I really need a solid lifter for a hydraulic flat tapper cam? I don't have one. I read you can put the indicator needle on the top of the lifter as long as its not the cup.
Second - I can't get the indicator far enough down to reach the lifter without using a bad angle that does not represent the angle of lifter travel. Do I need to get an indicator extension or am I just an idiot?
Third - once I get issues one and two worked out, how do I set my readings for the indicator? Does it matter where the cam is positioned when I set the indicator?
Appreciate the help on this
Old Jan 28, 2012 | 05:16 PM
cutlassefi's Avatar
First - do I really need a solid lifter for a hydraulic flat tapper cam? I don't have one. I read you can put the indicator needle on the top of the lifter as long as its not the cup. Get a flat tip for the indicator to ride on top of the lifter.
on. You just need an extension.
Once you rotate the crank around to intake lift on #1 cylinder you'll see everything move.
On your cam you're looking to have the degree wheel read 6 degrees BTDC when the lifter is at .050 lift. That will be a 106 intake cneterline, then you're good to go.
Hope this helps.
truerollers
Feb 28, 2017 01:00 PM
coppercutlass
Jul 17, 2015 07:32 PM
boese1978
Jul 11, 2014 09:41 PM
Slater442
Nov 23, 2012 11:29 PM
rgass
Feb 19, 2011 08:13 PM
