- BACKFIRING help
- Where to find manifolds?
- Manifold
- 1964 330 ci engine parts applacations
- trouble finding headers
- need help deciding the best exhaust!!!! HELP
- 71 Olds Cutlass downpipe question
- 7A Head Identification
- oil leak
- Ran into trouble guys....
- How to tell when harmonic balancer has moved-breaking down
- 73 Omega 350 upper and lower hose about same temp.
- Olds 350 Powered Firebird
- No oil coming to rockers
- Opinions welcome! SBO street/strip build
- Identifying High Compression 330
- Comp Cams Hyd. Roller Lifter and Edelbrock 3711 Intake?
- Opinions on valve covers
- 72 cutlass hot start problem, tried almost everything!
- Need help with Intake, Cam and Carb on a 350
- 1970 350
- Correct clamps for bypass hose?
- Overheating or a bad reading?
- Olds 215 Initial timing setting with a non-stock cam
- 324 ballast resistor
- Odd burning smell
- Small cam for a stock 350
- valve pan holes 87 olds
- Can I use this fuel-pump on my 330 without AC??
- 303 Rocker arm ratio
- 330 Engine identification.
- Engine #'s
- Oil gusher
- Head and Intake Gaskets - 1971 Cutlass
- 85 Cutlass Supreme 403
- Should I get a bigger carb?
- 355 SBO rebuild
- Spark plug gap for 68 350 w/ Pertronix?
- 330- Bore or not?
- Carb Jet sizes and gullible old me.
- 350 build
- Is it possible to remove oil pan while engine is still in car?
- Ugggg.another dilemma
- final words
- Bushings
- End seals
- Rocket 350 ugly sight
- oil pressure sender size???
- *VERY* Small Block Olds
- 307 timing adjustment
- 5A heads
- Headpipes
- Vacuum Leak or Normal noise?
- 350 oil pressure. (newb questions)
- 1968 Olds Cutlass 350 4 Blade Fan
- Flowmaster System
- Correct GM Belts
- 324 Olds Rocket
- Timing help.
- 1967 oldsmobile engine color and air cleaner color
- What engine?
- Can you put bb block heads on a sb?
- Edlebrock Performer 350 intake
- Short Water Pump Cross-Fit Autozone
- olds 403
- headers swap 455/350
- 324 Coolant Leak
- Ignition upgrade questions
- Torque Specs for Cam
- Cant seem to catch a break...uggg.. power steering problems...
- lazy 330
- Set of #5 heads
- 307 Alternator Bracket question
- Tightening down distributor causes engine miss and idle speed drop.
- Compression readings... What do you guys think?
- 307 overheating at highway speeds.
- Aftermarket Motor Mounts
- swapping heads
- Exhaust question
- Q-jet fuel feed questions
- verify valve timing/intake leak
- #4 heads?
- The time has come! now critique my setup please
- Thought's on roller valve trains...
- Total "Mound"ello of bull****
- Advice on Exhaust
- I want more giddy up, but how?
- 324 Manifold (98 Holiday Coupe)
- I really like my new Combo!
- 1964 Oldsmobile Cutlass 330
- Quadrajet vacuum help!
- what to expect from 1977 Olds 350 cutlass engine
- Edelbrock 1411 too much carb?
- How to Choose the Best Carburetor ?
- Head bolts and studs...where do they go???
- 2 barrel carb rebuild?
- 215 V8 main seal(s) question
- grannys back on her feet....
- heads,Ignition, and Intake install
- part number for replacement water pump hardware?
- advice on bringing old motor back to life
- 67 F 85 specs and engine data
- Manifold Removal
- Unk Vac Line
- Total Timing SBO
- Flywheel for Olds 350 Diesel
- spark plug wires issues
- Gasket questions
- 350 pulley questions
- Place to buy 330 rebuilt kit.
- 350 oil pump?
- need alternator bracket for 1972 cutlass
- HELP! Crack by valve cover
- Fuel pump mounting question
- Rocket 350 sluggish
- #2 heads rocker studs
- diagnose my knocking noise
- yet another fuel question .
- Edelbrock 1406 carb
- Am I bored or what?
- 350 id
- little carb issue with my new 650 dp holley
- Lookin for a new engine
- Bubbles in the radiator!
- Anyone running an Erson TQ40 cam?
- 72 350 rods?
- Sealing/gasket help
- Carb troubles
- 72 Cutlass dies while driving
- What type of puller for the crank gear?
- 350 backfiring through carb on heavy accel.
- rather productive day
- accessory mounting
- factory air valve
- Thrust bearing crush
- Fuel Infection
- Comp Cams magnum 280H
- Q-jet hot idle compesator
- Carburetor Troubles
- 1966 Cutlass lifter diameter?
- broken exhaust bolt
- 69 350ci quadrajet
- Holley Carb on Edelbrock Intake
- Intake manifold choices
- 68 Cutlass 350 Rocket Lifters Chattering?
- 2 to 4 BBl conversion
- Holley 4160 to 4150
- DIY 350 on a budget
- 1968 Olds Cutlass S Thermostat Housing
- Olds 350 Newbie budget build
- what pulleys are these????
- Heat Riser Valve 371
- 1967 cutlass 330 4bbl
- 61 F85 Oil pan Gasket
- Carb suggestions?
- Need an Olds engine builder in Indy
- swap meet 350 build.
- 72 350 Rocket w/4 bbl
- water methanol injection
- Olds 350 Alternator Bracket Question
- Carburetor Recommendations
- How hot is too hot?
- Charcoal Canister Leaking Fuel?
- Questions about identifying a small block
- Blowback
- 70 Supreme in need of help
- 350 repair
- SBO Rear Main Seal
- w31/ramrod heads
- Cam Bolt to Timing Cover Clearance
- 68 Cutlass 350 Rocket idling rough lately
- 403 into mid '70s X car
- Exhaust crossover
- stall question
- HV water pump
- small block.with nitrous
- Stock 350
- 69 350 question
- Push Rod Length Intake vs exhaust
- Distributor won't come out? 1970 350
- Engine stalling when hot
- Throttle linkage problem
- Lifter noise on my 371
- Got my 65 started.
- Questions about 2bbl to 4bbl and putting in 200-4R
- 350 water pump
- Which 350?
- Rocker Binding on stud base
- carb stumbling under part throttle; vacuum prob?
- small block or big block? you tell me....
- carb question
- Thermal vacuum switch
- 1964 cutlass 4 brl air cleaner info
- First Time Degreeing Cam
- 350/Edelbrock Owners - Chime in.
- Alternator Bracket
- fuel line / filters
- 350 apart, interesting observations
- Removing old head gasket
- 383 stroker
- 69 350 build
- 350 Afermarket Intake Manifold Bolts
- Harm. Balancer recommedations...
- 2 part rebuild on my 1970 350 50k original mile motor
- Blower kit
- 73 350 and #5 heads
- more engine pics in my 68 almost there
- underhood question heater hose related
- Distributor?
- cheap performance parts or my 330 and will the 350 parts fit
- one new engine photo
- engine photo updates...
- Ported Vacuum Switch
- HEI Conversion.
- Gaskets
- 63 F-85 swap kit
- Lifter noise
- Source for Gasket set? Heater core?
- Where do I begin?
- another spun bearing?
- Winter project - heads, cam and converter
- need help with changing headers
- Oh man, me and my luck...
- 350 Head Question
- Will Mondello Edelbrock Aluminum Heads help my Olds 350 Perform Better?
- quick disconnect starter wiring harness
- Name the Quadrajet!
- dating the engine
- 3" exhaust with stock manifolds?
- valve cover gasket question
- 1964 jetstar 88 rad hoses
- timing marks on 86 307
- SBO Intake Weight ?
- ac/AIR pump belt removed
- 2-bbl to 4-bbl. swap. Thoughts?
- Looking for headers
- Thermac air sensor
- Not Paying Attention to Detail!
- 67 330 supreme convertible engine question
- What's the difference between Low and High compression 330?
- hesitation at WOT
- 351c 1.73 roller rockers
- Edelbrock 2812 Victor Olds 350-403 Intake Manifold
- Leaking valve covers
- olds 350 w/ #4 330 heads on it
- #5 heads vs. #7a
- ?Any good olds engine shops in Los Angeles?
- need help timing olds 350
- Fuel Pressure 1970 Cutlass Sumpreme 350
