Rocket 350 ugly sight
Hello everyone, I wanted to see if anyone on here has ever seen a sight like this Rocket I pulled out of my Cutlass. I believe this one to be a 72, I pulled it out of the car because a friend of mine helped me try and tune the motor and ran across signs that this motor was shot. After pulling the motor I pulled the intake to re-use on the motor I am putting in and was shocked at what I saw underneath. After asking a few friends that are motor heads they said they had never seen anything like this. Have any of you ever see something like this. If so, what is it? And what would cause this? What does this tell you about the motor? Any thoughts would be great thanks
Carbon and sludge! You have some cleaning to do. Clean it up the best you can without it getting down into the block. Make sure all the oil returns are clear also.
I would pull each lifter one at a time and see if they are worn and concave. Return them back to the hole they came out of. If they are worn, a new set is probably in your future. I would also check all the pushrods to ensure the inside oil feed hole is clear and the pushrods are straight. I would also assume that you had a considerable amount of sludge on top of your heads. Clean and make sure your oil returns are clear up there.
OK, once you have that done and you reassemble and restart the engine, do not be surprised if the the rockers tap. If they do, you will need to replace some rocker assy's on the offending noisey ones.
I've seen worse! Good luck!
I am actually putting a different motor in. I just pulled the intake to use on the other motor. I currently have 3 motors for this car. The original which I plan on rebuilding over the winter, this 72 that I pulled out and a 77 with low miles that I am putting in. I had a thread on the site asking if I should use the intake off of the 72 instead of the one for the 77 and was told it was a good idea. I would like to get rid of this one but do you recommend I keep anything off of it? As I said I plan on rebuilding the original motor so I don't really need this one.
I believe that carbon buildup is due to the intake heat cross-over passages leaking past the metal tray gasket and discharging exhaust into the lifter valley.
This is the only reason I do not like the metal valley trays. They usually work great......if they're put on correctly, and torqued properly......but that is not always what happens in real life.
I've seen carbon like that semi- regularly upon teardowns. My buddy had one where you couldn't even see the push rods anymore. We ran 2 pieces of tubing from the drainback hole in the head down to the cam, and he ran it that way for 4 more years.
Didn't want to disturb all the crap in there because it would granulate and get in the oil and bearings.
this one actually didn't have one of the valley trays. Do you think it is worth keeping anything from this motor or should I just try to sell it as a core? If so what would be a good price to ask for it? No intake, carb, alternator, or distributor.
Cruddy smallblock known to not be running well -
You're pretty much working a little above scrap value.
For one that is claimed to be "good running" you might get $300 on a good day, after a long wait.
For that one, I'm guessing $100 if you're patient, $50 if you actually want to sell it (maybe $25 if it sits a while at $50 with no takers).
I wonder if the heads from yours looked as bad as mine did?
https://classicoldsmobile.com/forums...tml#post294407
to me that mess is more about using the wrong intake gaskets than lack of oil change... probably just kept adding and spun a new filter on every so often, having the exhaust crossover exposed like that will cause major oil comsumption! that thing had to have smoke rollin out the breathers big time!
All I know is that the blow by was so bad it made you nauseous while driving. And it looked just as bad under the valve covers. There was only oil coming out of 1 port on the driver side. @Lady72 I am trying to get rid of the core of that motor, the scrap yard I go to will give .15 cents a pound for it. I would rather sell it to someone but I currently have 3 motors and don't have room for it. But I have never taken heads off before and was thinking about trying it on that motor before I get rid of it. Good learning experience
That's about $75, which is more than you could probably sell it for.
Correction: Excellent learning experience.
I'd recommend completely disassembling it - no better way to learn!
BIGJERR
November 3rd, 2009 05:20 PM
