View Full Version : Small Blocks
- 403/350 heads dyno results
- Exhaust Questions
- Installing #5 Heads with Studs
- Steel vs Cast Iron Distributer Gear
- gathering information
- 1989 Olds 307 engine
- Was there such a thing as factory installed dual pcv valves?
- Starting concern.
- Oil ring question
- Changing Carburetor
- 1966 Cutlass Ultra High Compression Air Cleaner
- Engine Install
- 69 olds
- Quadrajet Jet and metering rod recommendations
- I need more power and i need it now!
- 69 350 with 5a heads
- Olds 350 with #8 head
- Missing ERG Valve? 71 Olds 350
- Sanderson Headers for 350
- 1977 350 help
- Anyone have experience with this vendor?
- MSD Module died
- Fueling issues?
- Starting issues and oil leaks
- Dyno or Synthetic
- Polishing chambers on #6 heads
- Looks pretty good for a 260
- Three dead cylinders puzzle
- Aftermarket timing cover ?
- W-31 head gasket question
- Replacement radiator 68 Cutlass S
- 303 Valve Stem Seals?
- DVCS questions
- Distributor question
- Bar Stop Leak
- Identifying a cam
- 1954/55/56 starter
- Blowby issues
- 295 hp 350?
- *****help****
- Timing gear removal
- Converting from single to dual exhaust
- Testing your HEI
- Which intake for 67 330
- Lucky 350 find?
- Intake runner lengths and sizes?
- oil pressure light flashing during break in
- No oil pressure after warming up
- Overheating for some reason
- Now I'm just confused
- Rocket 350 Build (long)
- 67 330 engine differences
- One step closer
- Ryan Weaver 1969 W-31 350 SBO engine build
- silhouette 3400
- hp
- 403 stroker build questions
- Quadrajet rebuild
- 403 with 350 heads what a difference!
- 1983 hurstolds 307
- Roller rocker mount
- 1972 350 bracket bolts.
- back pressure???
- 1970 350 4 speed w/AC; 393859 cam?
- build a 350
- High Idle Speed
- Compression test question -rocket 350
- what is Oldsmobile 350R motor
- Anyone know Holley 4160s????
- what are you guys using for ignition wire looms?
- olds valve cover breather
- Newb with a few 1971 questions, thanks for the help in advance
- Cam advice
- Newb with a few ingition/carb problems on 69 cutlass
- When to do compression testing
- help identifying these parts
- Need help to I.D. my motor
- 1964 Cutlass with a 1971 350 in it.
- Correct AC delco oil filter for 70 w-31
- Olds 307 swap advice
- Automatic choke on 2 bbl carb
- Quadrajet base leak
- Valve cover gromet for pcv valve in moroso standard height valve cover
- 1969 Cutlass S 350 2 brl intake manifold
- Oldsmobile 307 engine in 1989 Cadillac Brougham
- 371 J2 engine - bent rod - any ideas??
- Dipstick length
- 56 heads
- SBO Help
- Carb Question
- Best Header Selection for a '76 Cutlass Supreme
- What ignition coil.to use for stock 350?
- 4/7 swap
- engine not completely shutting down immediately
- SBO Intake options
- Exhaust leak or collapsed lifter? An annoying ticking noise.
- 215 coffee table?
- need tuning help
- Rocker Arms not straight
- Engine Decoding Help
- 1970 Oldsmobile Delta 88 350 no power won't start
- Dang Engine started Knocking
- Engine is extremely rough when starting in the morning
- Engine takes over a minute to start, no fuel visible in the filter
- Engine mounts
- New to the site and looking for some cam advice
- 350 stock manifold vacuum ports
- Piston Dome
- Cam Suggestions
- #8 Heads on a 350
- 330 Rebuild or Replace
- mixing up 350s
- Power Steering Pump Bracket
- Guideplate advice
- Gas in oil- 350 Rocket
- push rod probs
- Reusing old gasket is it possible...
- Oil filler tube question
- Cold air intake
- 215 cubic inch Rochester 4GC Stock Jet Sizes
- 403 rocker bridge
- Engine won't start
- Anyone recognize this harmonic balancer?
- 1984 Olds 307 running rough on startup
- Dick Miller Serpentine Pulley Review
- 350 plastic in the oil pan????
- 350 build advice needed
- 1987 cadillac olds 307 upgrades?
- 350 build questions
- Timing Concern- set high at idle
- 1979 oldsmobile delta 88, 350 "rocket" valve cover gaskets?
- Still ticking after valve adjustment
- 307 to 350
- 74 88 HEI hook up???
- Open element air filter
- Cam Profile for 350 Dual Quad Set Up
- Experience with Jet Performance Modified Quadrajets
- 1972 350 Engine Problem
- Show us your pulleys!
- RPM hood clearance
- 303 Lives
- 1970 Delta 88 Engine Compartment Stuff
- Choosing the right headers+starter: '72 Cutlass Supreme
- crankshaft pulley
- gasket advisory
- Front cover install trick
- Measuring piston to deck
- 350 olds
- 303 Points to HEI?
- distributor hold down
- The Number One Cause Of Reman Engine Failure butWith A Bullet
- Rocket 303
- 1975 olds 350 engine build
- 70 350 Cam Recommendation
- So moving on, what is a good HEI set up?
- 66 330 ignition issue?
- Need Help
- Tips for 10 hole valve covers on a 5 hole head
- Fuel vapor line or return line on my 72 supreme?
- Seville EFI 350 convert to carb
- Anyone know anything about these rods?
- Pushrod length
- Oil leaking from fuel pump 371 58 olds
- Where to get SS bolt kit for Performer RPM 7111
- Oil return passages
- Head gasket question
- Car died while driving
- Which water pump do i need? (dimensions)
- Shorty haeders
- Milling intake to match heads
- 350 Underhood restoration-A/C, Cooling, Timing set
- Need Help. Building a Roots Blown 350, How?
- Quadrajet running rich
- finally cracked open the block, good news! advice/suggestions
- Timing My 350 Rocket...
- March Performance vs Mondello Pulley/Drive System
- Ignition module died again...
- Retrofit?
- 1979 Rocket 350 oil pressure sending unit location?
- Piston volume stock style 403 pistons
- Engine Size and Year?
- New NOT running when hot issue, HELP
- How to remove the radiator
- Biggest valves in 5A heads
- Heads to use, '75 or '77
- Gold engine paint choices: best bang for buck
- what do i do now ???
- Carb/ secondaries won't open up
- 1982 307 timing
- 307 Options
- Post Break In Oil Change
- part connected to EGR valve off 350
- 330ci 39 or 45 degree cam?
- Motor mounts
- factory dual exhaust 1972 350 olds cutlass
- 1974 350 rocket tstat I should use??????
- In search of a 5.6" water pump pulley
- 71 A Body 350 4V MT Confusion
- A-Body Heater Core Replacement non-AC
- SBO Power steering pum fitment
- Basic engine question
- lifter tap $$ ?
- Camshaft Clarification
- Dual 330 Exhaust
- Rear main seal
- Still not right Edelbrock 1405 on 1972 Cutlass
- Oil galley plugs
- 1968 350 olds
- Timing
- How isn't this a common problem
- thornton manifold or long tubes???
- header...?
- Piston clearance
- Distributor gear for roller cam??
- Rochester 2GC rebuild - Missing parts?
- Toronado Crank Triggered Ignition
- OAI Air Cleaner Lid
- #5 heads
- Help with noise from fresh engine build
- Performer Vs Rpm
- Cheap little Performance Build. 76 350
- Excessive blowby coming through oil filler tube
- 79 cutlass diesel to 350 swap
- 350 Build in the Future
- 330 gas/oil mix
- 67 Cutlass engine code
- 307 rings Which one is top ring?
- Motor not running right !!!
- Timing Tape/Fuel pressure regulator install
- Oil/Gas help! Jetstar 88
- Persistant preignition (pinging)
- Why use a roller timing chain??
- new engine for my 56 olds 88
- Question on Intake
- Carb Identification - 1956 Rocket 88
- 350 Rocket Oil Capacity
- 1972 442 350 rebuild
- Thinking of getting a Holley
- Quick Fuel Slayer 750 Jetting
- 1979 Oldsmobile Holiday 88 "Rocket" 350 vacuum diagram?
- edelbrock aluminum intake
- Running Rich/White Exhaust. 76 350
- 350 Rocket Headers
- Re-using pushrods
- Will chev 327 rockers fit an olds 455?
- Timing cover Crank seal
- Oiling roller lifters
- 76 350 Shuddering/Jerking when Accelerating.
- 1971 350 Rocket Valve Stem Damage
