56 heads
Old Feb 19, 2016 | 05:34 PM
fatback's Avatar
56 heads
Can you use 56 heads on a 55 engine? If you use 56 intake?
Old Feb 21, 2016 | 03:16 PM
442Harv's Avatar
Not a expert for those years. But mt brother has a 56, and I know years ago, he bought a 55 parts car, and we switched so parts, not sure, as it was years ago, but the 55 motor was a 2 barrel, and he put the 56 4 barrel on it. I thought that all those 324 motors were the same?
Old Nov 26, 2024 | 04:56 AM
Wally's Avatar
As far as I know, the big difference between the 1955 and 1956 324 heads is the size of the valves. The 1955 heads have 1.750" diameter intake valves and 1.433" diameter exhaust valves. The 1956 heads have the same intake valves but have 1.562" diameter exhaust valves.
There is also a change to the intake manifold. If you put a 1956 intake manifold on a 1955 324, you need to use the 1956 valley cover which has a deeper indentation to accept the 1956 manifold.
madmax442.com
Feb 25, 2024 01:36 PM
56dunemobile
Apr 9, 2018 04:39 PM
fatback
Oct 3, 2017 09:26 PM
cmpcpro
Dec 22, 2016 04:51 PM
clloyd
May 12, 2006 07:28 AM
