Engine mounts
Old Jan 24, 2016 | 09:06 PM
1983oldsmobiledelta's Avatar
Engine mounts
I'm trying to pull my engine how to undo the motor mounts any other way then reaching up in the frame of the car and un doing the two bolts with nuts its on a 1983 Oldsmobile delta 88 any help thanks
Old Jan 25, 2016 | 07:08 AM
If you are talking about the two cross bolts that hold the rubber motor mounts to the frame pads, you need to get them from underneath. It usually requires a long extension on one or both ends.
Old Jan 25, 2016 | 08:11 AM
CRUZN 66's Avatar
Olds Fever
As Joe said, remove the 2 horizontal mount bolts separating the mount and frame pad... The 2 frame pad bolts are a little more difficult to remove with the engine and engine mount in place...
joesw31
May 31, 2015 04:17 PM
Nasty455
Mar 20, 2012 04:57 PM
flatoz
Mar 15, 2009 02:03 PM
jetsled
Mar 6, 2007 12:55 PM
Steed93
Jun 16, 2006 08:50 AM
