Engine mounts
Engine mounts
I'm trying to pull my engine how to undo the motor mounts any other way then reaching up in the frame of the car and un doing the two bolts with nuts its on a 1983 Oldsmobile delta 88 any help thanks
If you are talking about the two cross bolts that hold the rubber motor mounts to the frame pads, you need to get them from underneath. It usually requires a long extension on one or both ends.
joesw31
May 31, 2015 04:17 PM
