So moving on, what is a good HEI set up?
I have had good luck with the Pertronix Flamethrower HEI, stay away from the el-cheapo E-Bay crap. Also, not sure what year the vehicle is, (74 was HEI) but you can convert a points distributor and keep it stock looking if you have an older car.
I use to have a 74 Cutlass Supreme that originally came with a points distributor and no catalytic converter.
Yeah, I was mistaken, that was right around when they switched over. Again, if you want to keep it stock looking, convert the points dist to electronic and keep the external coil. Otherwise, drop in an HEI
joepenoso
June 4th, 2014 01:56 PM
