push rod probs
Old Jan 11, 2016 | 11:21 AM
jbates's Avatar
push rod probs
hi everybody I have a 87 salon with 85 front end a 68 350 in it. block numbers 395558 2 and head numbs 397742 5. I ordered pushrods 8.234" and too short. the old is 8.375 or 8 3/8" where can I get these and cheap. the prices I see are 100 something or am I wrong with this or maybe the liftrs are collaspt
Old Jan 11, 2016 | 05:33 PM
Octania's Avatar
Maybe the rockers and pivots are all worn out, which is more common in my experience.
Look at the contact/ wear points
Lots of USED pushrods are around.
All vehicles run on used parts.
Old Jan 11, 2016 | 09:21 PM
don71's Avatar
same but different
Maybe your engine has had some work done to it. Heads shaved,deck etc. This plays along with worn parts.
A typical lifter has compensation for .060. Doing the math your pushrods have a difference of 0.141. Thats more than twice the length a typical lifter can compensate for.
You need a checking push rod. Its adjustable. You measure it. You need one, two actually.
This is one of the last things you measure for when building a new(old) engine.
A hundred dollars is not out of the ball park for new push rods.
Old Jan 11, 2016 | 09:34 PM
Welcome to the site. Whats wrong with the ones that were on there?
Old Jan 11, 2016 | 10:00 PM
don71's Avatar
same but different
I just looked in an old catalog. It suggests 8.250. for small olds. Depends on whats been done to it.
Thats a starting point.
Welcome and good luck with the project.
Old Jan 12, 2016 | 07:32 AM
jbates's Avatar
push rods
hey thanks for the replys. you are right . I guess I need to quit being in a hurry . I have all winter too and no cash, just take it easy. thanks again.
Old Jan 12, 2016 | 09:29 AM
jbates's Avatar
push rods
I was just thinking if the heads were shaved woudnt the push rods be shorter.....
Old Jan 13, 2016 | 07:25 AM
jbates's Avatar
push rods
oh the lifters are tapping. the ones that are on there are all different sizes like their worn out so I thought I need new ones. my friend says it might be collaps lifters. but I still cant find the 8.3/8" sizes cheap any way.some are off 1/16th to 1/8" thanks for the help
m455sx
Sep 15, 2010 07:08 AM
65cutty
Nov 11, 2009 03:48 AM
maskinen
Aug 17, 2008 11:29 AM
subaruguru
Sep 17, 2007 11:54 AM
