Basic engine question
Old Sep 22, 2015 | 03:54 PM
denf221's Avatar
I have a 72 cs with stock 350, historically when I start the car it start to rev high as it warms and after couple minutes I just tap accelerator and it kicks down however the past couple times ive started it the motor wont kick down after tapping accel I practically have to floor it couple times for it to do so what does this indicate?
Old Sep 22, 2015 | 03:59 PM
It indicates your choke is probably sticking. Get some carb cleaner and spray the linkage.
Old Sep 22, 2015 | 04:34 PM
Macadoo's Avatar
Or the fast idle cam. Is that carb a little gunky? As Eric stated, get some cleaner and give it a good spray.
Old Sep 22, 2015 | 07:20 PM
denf221's Avatar
Old Sep 22, 2015 | 07:41 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Berryman's is the best I have every used. While you are at it, take the air cleaner off and spray some inside the carb.
Old Sep 22, 2015 | 08:21 PM
steverw's Avatar
Berrymans is the best, also spray it in the fuel float vent, and down the throat while reving the motor some. It will clean carb, intake, valves, combustion chambers. Its like a tune up in a can.
mefirst72
Oct 21, 2012 09:14 AM
DeltaDevil88
Brakes/Hydraulic Systems
Dec 30, 2011 01:57 PM
aviator34
Jun 28, 2010 10:25 AM
wolfman98
Mar 14, 2009 08:39 AM
deadbiker
Mar 31, 2008 03:00 PM
