basic tuneup questions for 72 olds cutlass
Old Jun 28, 2010 | 08:46 AM
aviator34's Avatar
i'm getting ready to bring my 72 olds cutlass supreme home for the first time and start the renovation process. i want to get the motor, transmission and brakes in shape before i do anything with the top and interior.
I haven't worked on an old car like this since i was in HS in the 70's and many things have changed. Tuneup parts and lubricants have improved or changed.
My question is do i need to worry about the type of spark plugs, wires, weight and brand of motor oil, tranmission oil, grease and so forth when i go to change those things out. In other words i dont want to put something in the engine or transmission that it isn't going to like and risk damaging something.
thanks,
Dave
Old Jun 28, 2010 | 09:54 AM
Oldsguy's Avatar
Past Administrator
Use what is recommended for oil weight, tire sizes, etc. For replacement parts, no need to go overboard with super hi-tech spark plugs, just OEM replacement type like AC or Champion brands. For tires, radials are going to be ok instead of bias plys
Old Jun 28, 2010 | 10:25 AM
Lady72nRob71's Avatar
Oil has changed for the worse, when used in old cars with non-roller cams. The zinc content (zddp) is lacking, so i recommend diesel 15w-40 which has much more zinc than regular oil.
When regreasing ball joints, use plain ol' grease - nothing exotic. This is what the service stations use and I heard it is not a good idea to mix different kinds of grease.
Tranny fluid and axle oil should be as per mfgr specs.
dc2x4drvr
May 4, 2020 06:00 AM
wrath
Mar 20, 2015 07:52 AM
DeltaDevil88
Brakes/Hydraulic Systems
Dec 30, 2011 01:57 PM
bammax
May 9, 2011 08:36 AM
deadbiker
Mar 31, 2008 03:00 PM
