Olds 350 with #8 head
Hello, Im doing a head gasket on my olds 350 but im not sure which vehicle i get the parts from. the block is stamped 395558-2 and the cylinder heads are #8. i am replacing the cylinder head gasket,push rods,lifters, valve stem seals, and cylinder head bolts and exhaust manifold bolts. if i can be pointed to the correct vehicle to source the parts from that would be awesome. Thanks
Any 68-76 Olds V8 use the same head gaskets except the 260. Say a 1973 Olds Cutlass, it will work. Be aware you will be dropping your 7.9 to 1 compression to about 7.5 to 1 with aftermarket head gaskets.
But, of course, once the heads are off, you can take them and get them milled about 0.090" and gain about a point of compression, instead of losing half a point, and improve both your performance and fuel economy.
A little off topic, but how far have people milled there iron heads. I believe Mondello always said .060" was the limit, but others have gone further with success.
If you are planning to install the springs and seals yourself go for it; but, no matter who assembles them be sure to vacuum test/seal check the final valve job before putting the heads on the block. This is literally a five minute procedure at a machine shop that cannot be done unless the heads are assembled, it confirms that the newly done seat grinding and valve grinding make a proper seal. Ask them to show you how it is done to learn.
Good luck!!!
Good luck!!!
Good luck!!!
Good luck!!!
Of course, it's not like I can claim that my projects never drag out for years...
lemoldsnut
Mar 23, 2017 11:25 AM
