Olds 350 with #8 head
Old Apr 17, 2016 | 09:17 AM
512Lac's Avatar
Hello, Im doing a head gasket on my olds 350 but im not sure which vehicle i get the parts from. the block is stamped 395558-2 and the cylinder heads are #8. i am replacing the cylinder head gasket,push rods,lifters, valve stem seals, and cylinder head bolts and exhaust manifold bolts. if i can be pointed to the correct vehicle to source the parts from that would be awesome. Thanks
Old Apr 17, 2016 | 12:35 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Any 68-76 Olds V8 use the same head gaskets except the 260. Say a 1973 Olds Cutlass, it will work. Be aware you will be dropping your 7.9 to 1 compression to about 7.5 to 1 with aftermarket head gaskets.
Old Apr 17, 2016 | 06:08 PM
512Lac's Avatar
Is this something i should be worried about on the loss of compression? the engine is a stock engine in a daily drive only after martket is the edlebroke high rpm intake 7111 & 1406 edelbrock carb.
Old Apr 17, 2016 | 06:42 PM
You should be fine, the cheap Fepro head gaskets will give you around 7.7 to 1, not the end of the world on an otherwise stock daily driver.
Old Apr 18, 2016 | 06:30 AM
But, of course, once the heads are off, you can take them and get them milled about 0.090" and gain about a point of compression, instead of losing half a point, and improve both your performance and fuel economy.
Old Apr 18, 2016 | 09:06 AM
80 Rocket's Avatar
A little off topic, but how far have people milled there iron heads. I believe Mondello always said .060" was the limit, but others have gone further with success.
Old Apr 18, 2016 | 09:16 AM
0.060" is conservative with low compression heads.
And remember, the first 0.030" just brings everything back to where it was before you added the thicker head gasket.
Old Apr 18, 2016 | 11:51 AM
If he does that, he should swap the stock turd cam and get the machine shop to use a cutter under all the exhaust valves.
Old Apr 18, 2016 | 05:42 PM
No argument here.
Old May 6, 2016 | 10:25 AM
512Lac's Avatar
so should i torque the heads to 80 ft lbs or 130 ft lbs if using parts from a 73 cuttlass
Old May 6, 2016 | 11:51 AM
85 foot pounds is the specified torque for the 1973 Olds V8s.
Old May 6, 2016 | 01:19 PM
512Lac's Avatar
Old Oct 27, 2019 | 08:51 AM
Sugar Bear's Avatar
If you are planning to install the springs and seals yourself go for it; but, no matter who assembles them be sure to vacuum test/seal check the final valve job before putting the heads on the block. This is literally a five minute procedure at a machine shop that cannot be done unless the heads are assembled, it confirms that the newly done seat grinding and valve grinding make a proper seal. Ask them to show you how it is done to learn.
Good luck!!!
Old Oct 27, 2019 | 09:56 AM
Good luck!!!
This thread is from 2016. I hope the engine is back together by now...
Of course, it's not like I can claim that my projects never drag out for years...
lemoldsnut
Mar 23, 2017 11:25 AM
455cutlass1969
Dec 3, 2013 10:09 AM
my71olds
Aug 14, 2013 05:49 PM
jslabotsky
Apr 19, 2012 05:03 PM
Stevec
Feb 9, 2012 01:54 PM
