Timing gear removal
Old Mar 20, 2016 | 08:51 AM
Mike Sundy's Avatar
Timing gear removal
Hey guys, is there a trick to removing the timing gear from the crank or should I just pry it off? Thanks for the advice.
Old Mar 20, 2016 | 08:56 AM
I've found this to be helpful:
Old Mar 20, 2016 | 09:00 AM
Also, be sure to thread the balancer bolt back into the snout before using a puller, to avoid possibly messing up the threads.
Old Mar 20, 2016 | 09:02 AM
Octania's Avatar
If it's tight, and I have seen them anywhere from finger removal to "break the puller" tight...
use a chisel to crack it at the keyway thin spot, and it will come right off, other than the drag of the tightly fitted key in crank's keyway...
Old Mar 20, 2016 | 09:03 AM
Occasionally, if it's really stubborn, it may be helpful to split it at the keyway with a cold chisel.
edit: Jinx! Great minds think alike.
Old Mar 20, 2016 | 09:26 AM
Octania's Avatar
how does a picture of a puller help??
Old Mar 20, 2016 | 11:40 AM
ELY442's Avatar
I didnt have a puller at the time so I use 2 pry bars with the angle tip and pry it at the side of the gear against the block and it came right off.
Old Mar 20, 2016 | 03:56 PM
Or this...
80_cutlass
Sep 1, 2018 05:55 AM
Cman7713
Drivetrain/Differentials
Mar 20, 2016 08:11 AM
drjr56
Sep 9, 2012 08:05 PM
442scotty
May 13, 2009 05:42 PM
smcurro
Feb 27, 2009 09:27 AM
