1977 350 help
1977 350 help
I bought an olds 350 quadrajet 4bbl with a turbo 400 attached and when I got it dropped into my car it started and ran for about 20/30 seconds and then died and hasn't started since. It fouled the plugs after trying to get it restarted so then I swapped them and also changed the starter and replaced the leaking water pump with still no luck on a restart. I have tried to time it by raising piston 1 to TDC and pulling the distributor out. It wants to run with the starter but still won't run on its own. It sucks gas from a gas can but won't run and back fires like hell when I adjust the time either way any thoughts?
Make sure the distributor rotor is pointing to #1 at tdc. Make sure your firing order is correct and wired for the distributor that turns CCW. Make sure you have 12v to the coil+ in both start and run positions of the ignition switch.
It has an hei distributor I think from the factory and it is wired correctly I have made sure it is pointing at 1 TDC
I was wondering if that could be the problem. So let me ask a question when I have the dizzy cap off the rotor has a black end which end should point to the cylinder I want to start with
I think my buddy has that pointing towards passengers rear the car has the symptoms of being 180 out but my harmonic balancer doesn't line up at all and I tried to break the center bolt loose and after 2 days and every size socket wrench I own it wouldn't come off. It wants to rotate with the wrench or breaker bar
The harmonic balancer has a line running across it that should line up with the scale when you are at TDC using the #1 cylinder. At that point you have a 50/50 chance the engine will fire and run with your rotor pointing where the #1 spark plug wire is in the cap. If for some reason it is back firing and kicking back then it is 180 out and the distributor needs to be pulled and turn the rotor 180 degrees from where it is at that moment and reinstall.
There is no need to pull the harmonic balancer unless it is bad and has slipped.
So loosen the hold down bolt on the distributor, lift the distributor until the gear disengages, rotate the rotor and stab it where the rotor is 180 degrees from where you started. Sounds 180 out to me.
I have done that and got it to stop back firing I think I am a notch or two off still but am about to try again and see what happens
Good to hear you almost have the problem fixed. I would have thought the timing chain would have been the culprit, happy I didn't post and throw you off with a diagnosis.
These guys are awesome here !!
I would like to see some pics of your 77 .
Eric
Eric
I thought I was close but it still wouldn't fire off. I have #1 TDC on compression for sure I pulled the cap and the black part with the metal tab is pointing at #1 this time it back fired from the manifolds and carb?
Have you pulled the #1 spark plug out to see if the piston is at the top then verifying rotor is facing #1 ? It sounds like you have, and all plug wires are proper. You timing may be way out.
Eric
Eric
I have the #1 up all the way I made a mark on the H.B. Where 0 is on the tab the rotor is facing #1 when I try and start it I can get it to be sluggish and back fire and then as I turn the dizzy it starts to want to run and then just starts turning over and over with the starter until I get my buddy to turn the Ign. Off
Get it to where its running on its own by turning the distributor as you have been, allow it to run for a good 5 min giving little throttle blips. If it continues to backfire with little blips tell us if the sound is like a popping sound coming up from the carb. Are sure the plug wires are in the proper position on the distributor. Open up the butterfly and keep it open at the carb while feathering the throttle as well until it warms up a bit.
Here's where I'm at now
And why not confirm TDC properly, with a premade TDC-finder or homemade bolt-through-sparkplug-base version?
Thus far we have confirmation of exactly nothing being correct in your engine - we do not know whether you have a good spark, we do not know whether your carburetor is supplying gas properly, we do not know whether your valve timing is correct, and we do not know whether your spark timing is correct. Therefore, it is very difficult for us to give you effective advice.
There is no such thing as being a few notches off unless the vacuum advance is hitting something preventing you from turning it enough for proper timing. You may have to rotate the distributor one way or another to get it to fire off. You also may have to turn your idle speed screw up for it to keep running on its own. Since its blowing fireballs, I'll assume you have fuel.
If you can't figure out the lines, at least cap all the ports so you don't have vacuum leaks. The engine will run fine until you figure them out. Glad you got it to run. Don't know about the flat lobe your neighbor is talking about because we can't see or hear it run from here. Get everything adjusted and all your lines right and go from there.
The carb is leaking gas onto the top of the manifold on the passenger side anytime I put gas into the top. I think this could be one of my problems with the flooding issue but would that cause the car not to idle at all?
Why are you putting gas into the top of the carburetor in a car that is run regularly?
And, since you are putting gas into the top of the carburetor, why are you surprised that it is running out?
This is the first time it has been able to be started and ran since it was put into the car. It won't pull gas from the tank even with a new sending unit so it has been running out of a can and the return line to a separate can the car won't start unless it is primed with gas into the carb and after it starts sucking from the can and running for a few minutes it starts leaking gas onto the manifold around cylinder 4
I swear I just typed this somewhere:
Heavy float, incorrect float level, or needle and seat not sealing.
Also, remote possibility of fuel pump pressure too high.
Check your fuel pressure, then take your carburetor apart.
It's not the F.P. Pressure for sure I think I'm just going to rebuild the carb I'm tired of fooling around with it. I know for sure it hasn't been rebuilt since the motor was new.
I'm pretty sure the guy who had the car before me put a bigger cam in it atleast that's what the guy who sold it to me said
I finally was able to get the car to run on its own I'm going to get a timing light on it and a vacuum gauge on the carb and hopefully make it run a little better. Is it possible to have 4a heads on a 350?
I guess but probably is a 403. There is a casting number behind the water pump beside the oil fill tube. The 77 and up have displacement cast into the side of the block, should be a big 403.
