Retrofit?
Old Nov 2, 2015 | 06:53 AM
orangepower1987's Avatar
Retrofit?
Hey masters of the small block,
I have a 65 Olds 330 Small Block that I plan on dropping in my 1971 Cutlass S when the time comes. However, it doesn't have pulleys. Currently in the 71 there is 350 small block with fan and pulleys. My question is this: can I use the pulleys and fan on my 330? If so, how intense is it? If not, what are some viable options?
Thanks!
Old Nov 2, 2015 | 09:59 AM
Thanks!
The blocks are externally identical. Swap the water pump, pulleys, brackets, and accessories from the 350 as a matched set to avoid belt alignment problems. Be sure to properly reinstall the two spacers between the PS pump bracket and the block.
Old Nov 2, 2015 | 05:05 PM
Thanks for the help Joe! I 'll post updates as they come.
Old Nov 3, 2015 | 07:36 PM
nsnarsk65cutlass's Avatar
You will need to use the 330 flexplate as the 350 is different.
Old Nov 4, 2015 | 06:59 AM
Good point, I should have mentioned that. The crank flange on the 1964-67 motors uses a different bolt pattern than on the 1968-90 motors. You need the flexplate or flywheel that matches the crank.
dc2x4drvr
May 26, 2014 08:59 AM
OLDSmobility
May 2, 2014 03:21 AM
dfrede
Oct 16, 2013 06:23 AM
jimjr
Oct 5, 2010 03:45 AM
TheBirds
Sep 24, 2010 09:40 AM
