Reusing old gasket is it possible...
Old Jan 10, 2016 | 12:05 PM
Kyron219's Avatar
So i pulled my heads today and the gasket is very much in place no dents or dings just has gasket material on it...Rtv etc....If cleaned well can i reuse them not scraping them..69 350 #5 heads
Old Jan 10, 2016 | 01:15 PM
No, you can't reuse stock head gaskets, one time use only. If your just going to put is back together any one of these can be used. If you want to maintain your compression then the heads need to be milled down the difference in thickness between the old steel shim gasket and the new replacement.
http://www.rockauto.com/catalog/rafr...ktemplate=true
Old Jan 10, 2016 | 01:17 PM
m371961's Avatar
JMHO. The risk of engine damage is not worth reusing a head gasket.
Old Jan 10, 2016 | 01:18 PM
No, do not reuse head gaskets.
Old Jan 10, 2016 | 01:41 PM
Kyron219's Avatar
Thanks guys but i took a closer inspection and those gaskets have small weep wholes in them so now im looking for replacements.......Is there any place i can go for direct or close to oem..
Old Jan 10, 2016 | 01:53 PM
I included a link in post #2 or you can get some at your local auto parts store.
Old Jan 10, 2016 | 02:01 PM
Kyron219's Avatar
Thanks eric it even has the part number i pulled off the oringals and thats what i always look for.....But those are rubber are there any others
Old Jan 10, 2016 | 02:09 PM
Not without spending a lot more money. I would recommend a proper sized one of the gaskets in the link below if your doing a performance rebuild.
http://www.summitracing.com/search/b...e?PageSize=100
Old Jan 10, 2016 | 02:33 PM
Kyron219's Avatar
Well i am looking get about 380 hp out of her....will these gaskets work
Old Jan 10, 2016 | 03:03 PM
Yes the gaskets will work, but will the rest of your build support 380 hp? Compression ratio (what pistons?), intake, cam, etc?
Old Jan 10, 2016 | 03:09 PM
Kyron219's Avatar
Might just send it off to be rebuilt dont have the time or space right now...but 380 is my goal something nice..
Old Jan 11, 2016 | 10:37 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
For 380 HP you will need 2.07/1.625 valves plus bowl and port work or Procomp/Edelbrock heads. Plus flat top pistons and a pretty large cam, headers, higher stall and deeper gears to run well together.
nonhog
Mar 6, 2013 09:40 AM
costpenn
Brakes/Hydraulic Systems
Sep 13, 2011 03:40 PM
defiant1
Apr 1, 2011 08:01 AM
PetChemMan
Aug 8, 2010 07:39 PM
Sixoh
Aug 8, 2006 05:11 AM
