Reusing distribution block ?
Old Sep 12, 2011 | 08:06 PM
costpenn's Avatar
Finally got around to pulling the brake/fuel lines off the frame of my 72 (drum brakes). Still had the original brake distribution block which looked awful, and I was planning on replacing with a repop. But after spending some time on the wire wheel, the thing looks great. Have repeatedly rinsed it with carb cleaner and blown it out it - it seems to have no restrictions. Since it is just a distribution block - Can it be reused, and does anyone sell that plastic switch in the top of it seperately?
Old Sep 13, 2011 | 06:24 AM
Yes it can be reused!!
Old Sep 13, 2011 | 06:33 AM
Tony72Cutlass'S''s Avatar
i totally reused mine and the breaks worked great back when my car was running a couple weeks ago.
Old Sep 13, 2011 | 06:38 AM
Actually Joe, i didnt even clean mine out as well as you, i just dunked it in some brake fluid and cleaned it out with a brush... So i'm sure you're good to go!
Old Sep 13, 2011 | 11:04 AM
costpenn's Avatar
Thanks guys - I was worried that there might be some seals or something else internal that wears out. The block itself is pure brass (?), what is the correct finish for the attaching bracket?
Old Sep 13, 2011 | 01:49 PM
jensenracing77's Avatar
for brake systems i think denatured alcohol is the better thing to use.
Old Sep 13, 2011 | 03:40 PM
rcorrigan5's Avatar
Randy C.
I reused mine and it works great, even after it had been sitting around for 25 years!
Randy C.
garys 68
Brakes/Hydraulic Systems
Sep 18, 2012 10:20 AM
Team13Racing
Aug 11, 2012 09:37 PM
dgy
Apr 6, 2012 11:03 AM
Bluemeanie
Nov 5, 2011 09:25 AM
olds4life
May 4, 2011 09:57 AM
