Reusing head gaskets?
I read somewhere (BTR's book?) about reusing factory head gaskets.
Anyone do this?
I'm not comfortable doing it. Just curious. Cleaning the shop and ran across a couple that didn't make it to the round file.
Also is the turkey tray a one use deal?
Anyone do this?
My take is once you crush the embossed sealing part of the gasket it's done, a one time use. So that would be stock shim type head gaskets and turkey tray type gaskets.
Considering how cheap they are why take the risk, just buy a new one.
Yeah +2 for what they said, why would you want to skip on putting new in. chances are if you put used head gaskets in it WILL leak into the cylinder, and we all know that is bad.
Use NEW head gaskets and don't forget to torque to right spec and proper sequence.
_Luke_
_Luke_
Head gaskets aren't something to take a chance on, considering all the work involed to replace leaky ones. When I built my last engine, used Fel-Pro Blue gaskets, with a light coat of Permatex copper spray(recommeded by the machine shop). No leaks yet. I also liked some of the older tv shows, and hear Eddie Albert lived to be 99 years old.
I have heard of glass beading the factory steel head gaskets and reusing them. I have not personally known anyone who has done this. I think they are 0.019 thick. The small gain of compression has never been that important vs taking a chance on a leaking head gasket. Serious drag racers may chime in on this and maybe one has tried it with success. Ken
Like I said Cometics can be reused. I used one set 3 times when my iron heads were imitating a sprinkler system. Just replaced the last set, they do cost a little over $200 but are custom made and are MLS. They make them to your specs (bore, thickness, bolt/stud size) They can be had .021 or .024" thick. You have to have the right texture surface tho.
Trip, the gaskets didn't leak.........the iron heads did from too much porting........walls too thin.
The last gaskets (with the RR heads) were used twice and we decided to change them "just in case" since we had the heads off. You will like them
Take a look over on HPO in the Anything Goes section at a thread I started about Greg's Performance. I was not a happy camper.
.Take a look over on HPO in the Anything Goes section at a thread I started about Greg's Performance. I was not a happy camper.
I've been thinking about who told me that, it was a Chevy Guy. As we all know, with a Chevrolet engine one can get away with anything. Sorry nobody could put this myth to rest one way or the other. Ken
I have reused the oem steel gaskets several times,no problems.I did so to not lose any compression. I would not do this on an expensive rebuild though.
I've done it once and it worked out fine on a BBC. But the heads and block were machined and it was fresh and un fired. I had an issue with something and had to pull the head. I put it back on and went an extra 5 pounds n the torque.
And the part everyone in this thread seems to have left out is the use of a soft copper wire as an O-ring. Still not something I'd waste my time on. If you're worried about losing a little CR due to thicker gaskets, mill the heads to make up the difference in gasket compressed height.
