Reusing old gasket is it possible...
So i pulled my heads today and the gasket is very much in place no dents or dings just has gasket material on it...Rtv etc....If cleaned well can i reuse them not scraping them..69 350 #5 heads
No, you can't reuse stock head gaskets, one time use only. If your just going to put is back together any one of these can be used. If you want to maintain your compression then the heads need to be milled down the difference in thickness between the old steel shim gasket and the new replacement.
http://www.rockauto.com/catalog/rafr...ktemplate=true
Thanks guys but i took a closer inspection and those gaskets have small weep wholes in them so now im looking for replacements.......Is there any place i can go for direct or close to oem..
Not without spending a lot more money. I would recommend a proper sized one of the gaskets in the link below if your doing a performance rebuild.
http://www.summitracing.com/search/b...e?PageSize=100
For 380 HP you will need 2.07/1.625 valves plus bowl and port work or Procomp/Edelbrock heads. Plus flat top pistons and a pretty large cam, headers, higher stall and deeper gears to run well together.
